- Joined
- Feb 6, 2024
- Threads
- 6
- Messages
- 556
- Reaction score
- 449
- Location
- Yavapi County, AZ
- Vehicle(s)
- 2024 Type R
Rod and crank bearings would be most affected by loss of oil pressure. Cam bearings generally less of an issue, unless larger wear particles were injected.
Plenty of cam lobe pics, but we have roller tappet engines needing very little lube on roller surfaces compared to crank/rod plain bearings.
Change oil yourself with Honda 0W-20 and see if idle oil pressure is below 15 psi with hot oil (210F for example).
It's been said in this forum that below 15psi at idle and below 59psi at 3000rpm isn't good.
