Honda won’t give me engine data
cyirush
Craig
Long Beach CA
2005 Lotus Elise; 1968 MGB; 2016 Nissan Leaf
My ‘25 CTR was stolen last week and recovered.
It’s at the dealer getting inspected.
I asked them to pull the engine data to see if there was a mechanical over rev. They said Honda won’t let them!
I called American Honda and got the same answer.
I want to know how the engine was treated in the 1/2 day the thieves had the car before I sign off on the insurance claim.
Any other options? Could an aftermarket tuner in my area do it?
cyirush
Craig
Long Beach CA
Did some research and looks like the car stores a code if there is an over rev. The dealer said they can pull codes so maybe I don’t need all the engine data.
Still, they should give it to customers.
marcusm86
Marcus
Missouri
2025 Civic Type-R
what "engine data" are you expecting?
johnloov
John
The engines are basically bullet proof. Wouldn't worry about the over rev. Sorry to hear about the theft.
tezzasaurusrex
Terence
You'll get a P0219 Engine Overspeed Condition code stored if a proper over rev occurs. And that doesn't necessarily mean the engine has sustained actual damage.
cyirush
Craig
Long Beach CA
Mainly if there was a mechanical over rev (money shift).
Thanks, read about that after I posted this. Makes me feel better as the dealer can pull codes.
cyirush
Craig
Long Beach CA
I like your optimism!
Bootyfett69
Ya moms
2025 FL5 Type R
Can confirm that they are bullet proof. Over revved mine to 8477 and have had two oil analysis done since, both perfect
That being said, just because it can handle it doesn’t mean I would want to have it done by someone else to my vehicle
I would absolutely get that checked before signing off OP. I over revved my car, that’s different than someone else beating on your vehicle.
Civic_Type_R_
Jacob
Washington
That's F'd up it was stolen. Just curious of how 🤔 wondering if there's some preventive measures one could do? I'm new to current Type R's
cyirush
Craig
Long Beach CA
Dealer is finished working on the car.
They did pull the codes. There was a P0219 engine code for an ‘over speed’. Car was revved to 7667 rpm and driven at 129mph.
It’s passed a visual inspection and been test driven and the tech says engine and transmission functioning normally. No strange noises.
cyirush
Craig
Long Beach CA
Did it throw a code (P0219)? If so, has the dealer detected it. Could be used to deny a warranty claim?
Bootyfett69
Ya moms
2025 FL5 Type R
Yes it threw a code. The dealer is who gave me the exact RPM of the over rev, I was honest with them on what happened.
Ultimately just replaced bearings and did a couple oil analysis.
Warranty is almost assuredly gone but I didn’t specifically ask, don’t really care at this point. The car will be tuned before the warranty was up anyway
tezzasaurusrex
Terence
7667rpm is nothing, we regularly get there just downshifting a little early entering a slow turn on the circuit. Get the valve clearances checked and adjusted. Send your next 2-3 engine oil changes out for analysis for abnormal wear materials. If all clear, you can sleep easy.
cyirush
Craig
Long Beach CA
Are you talking about on a stock Type R engine?
Aren’t the valves hydraulic?
Interesting that they didn’t say warranty was gone explicitly.
Did you replace the main bearings on the crank?
