2025 Si full digital cluster works in 22-24 and here's what you need to get it done!
Johaw
2023 Civic si
Stuff came in today ?
Are you doing the install yourself or having the dealership do it?
if you are doing it yourself id recommend scheduling an appointment now to ensure you arent waiting long with your dash apart ( my mistake)
If you are having the dealer do it see you in the crew soon
Shankmeyster
Shankmeyster
AZ
23 Type R
Looks like I have a pinched wire somewhere inside the wheel as I am having intermittent LCA and ACC warnings come up. Gonna have to have them open it up and possibly replace the harness again. We shall see. The joys of upgrading.
Rizzy4magic
Ricardo
Civic SI
I'm going to have to dealership do it. I have a friend who works at Honda
Johaw
2023 Civic si
Honestly that is a really easy part to do if u dont wanna spend the time going to the dealer takes 1 min to get the airbag off so you can check
Shankmeyster
Shankmeyster
AZ
23 Type R
Looks like the cruise button cluster is on backorder as well now.
Colbycollett
Colby
Largo Florida
2022 civic si
I started a thread a little over a year ago to see if any of the digital clusters would work on the Si, but none of them would work without errors as every other model has options that the US Si does not. Well I became the guinea pig today to do the first test of whether the 25 Si cluster would work, now that we have a full digital option for the US Si. I'm here to tell you the swap works!
It took ordering 4 parts from the 25 Si, a trip to my local Honda service department, and 3 hours of labor, but it is fully functional AND you get a few new extras with the cluster. Below are the 4 parts you will need to order to make the swap work. I was told to beware that, once you do this swap, your OEM cluster will no longer work, and you will have to order a new OEM cluster and have it programmed back, if you decide to put it back to stock.
Are oem parking sensors compatible with this gauge cluster?
Shankmeyster
Shankmeyster
AZ
23 Type R
So far as I'm aware this cluster will only work on the US Si which does not have sensors.
Shankmeyster
Shankmeyster
AZ
23 Type R
So yeah, the harness was stretched/installed incorrectly apparently so it's all fixed now. Make sure you check if you install it yourself.
Johaw
2023 Civic si
Made sure to take a picture of my original harness and match up the new one exact when i put it in to avoid any mishaps may check again just to be 100% though
Shankmeyster
Shankmeyster
AZ
23 Type R
Better add that #5 in your sig
