3D printed fender rock guard installed on FL5
phononmode
PA
2024 type r
Don't want to pay $70+ for a part that is meant to take damage, so decided to make my own. After many revisions and tests, finally installed my 3D printed ones on my FL5. I'd like to share some thoughts on how to get the best print.
First of all, I used a paper and pencil to trace the outline of the finder vent, scanned it, then modeled it in Solidworks. I used hexagonal grids with 83% air flow area.
11th Gen Honda Civic 3D printed fender rock guard installed on FL5 fender_guard
Printed out on my 3D printer with build-area of 300mm x 300mm. 4 mm nozzle size - first layer thickness of 5 mm. Since it's not really a "3D" print but rather a large area 2D sheet, you want to slow the print speed of the first layer down to ensure good adhesion to he build plate and between lines - I used 20 mm/s and 0.1 mm height for the first layer. The print turns out to be pretty good, both in strength and cosmetically.
Material used is PETG, for weather and environment resistance. Do not use PLA, it won't survive outdoor use (I've tried it).
11th Gen Honda Civic 3D printed fender rock guard installed on FL5 1748799287993-7k
11th Gen Honda Civic 3D printed fender rock guard installed on FL5 1748799298773-y
For the install, the push retainers are suuuuper difficult to remove. I suggest just use a wire cutter to destroy the clips. Do not try to preserve these clips - you risk damaging your paint if you slip and the tool strikes the panel (I caused a small chip on mine). Get new clips from your autozone.
11th Gen Honda Civic 3D printed fender rock guard installed on FL5 thumbnail_IMG_1133
11th Gen Honda Civic 3D printed fender rock guard installed on FL5 thumbnail_IMG_1132
Picture of the installed rock guard:
11th Gen Honda Civic 3D printed fender rock guard installed on FL5 thumbnail_IMG_1137
11th Gen Honda Civic 3D printed fender rock guard installed on FL5 thumbnail_IMG_1135
Final thoughts:
The material is pretty strong, I tried to intentionally break the material at 0.5 mm and it took a lot of force. I end up print 0.7 mm - that's the thickest it can go to use the push retainers above (and probably same for factory clips).
If it breaks I can just replace it since it's cheap to make. I may try to find some push retainers that are easier to remove than the factory ones. I think any 8 mm retainers can work.
Mrjustin81
Final thoughts:
Pretty cool man. And F those clips
Evox787
Elvin
wow 3d print is the future and the people who know how to use it will be banking. Amazing man I wasn’t lucky I pay 80 I think for mine but good that you could do this now start selling them make them affordable for everyone.
CTR
strixauto.com
2023 Civic Type R, 2020 GX460
Looks identical to Flap Fab. I expect that the hexagonal area won't survive as well as a sheet of plastic that is cut like their deign. My experience with 3D printing tells me those areas will be weak.
Cool project though!
phononmode
phononmode
PA
2024 type r
That's definitely the case. The metal ones will be much stronger. I used some ironing on the top layer to strenghen the bonding between the lines. Initial thought was if it breaks I can just replace it, but the clips are so annoying lol. Broke one finger removing the clips so hopefully it can last a while.
aiggy
Miami,FL
2025 Honda Civic Type R
My car had less than 1k miles when I installed rock guards and those clips were already a MF to take off and I also hurt myself along with breaking the clips. Well, a few not all.
Nanook
JP
Chester, VA
Those clips are crap! I broke nearly all of mine trying to remove them and the car had less than 300 miles on it. So brittle
fchanovski
Francis
25' FL5
I'm glad I'm not the only one breaking clips, thought it was skill issue lol
Broke 3 of 4 trying to install rock guards. I count that as a win!
Zpeedster M
New York
2023 Type R FL5
I stripped 2 of the 4 bolts for the undertray because they must have been attached by Honda robots but somehow managed to take out first 3 clips and just brake the last one for the fronts. I actually reused the 3 to attach my splash guards.
jporter9
Jeff
Knoxville, TN
2025 Type R, 2016 Civic EX Sedan, 2019 Honda Odyssey Touring Elite
Final thoughts:
Any way I can get the SolidWorks file? I’m picking up my FL5 next week and can print these at work. I also have a friend from ORNL who said could have a set made for me in aluminum and possibly carbon fiber.
sawixso81
MI
2018 CIVIC SI
Plus one on that! Would love that file too if possible. Company called PCB WAY also does custom stl file\3d printing as well
ThePS1Addict
Josh
Could I get that solidworks file as well? I actually work with solidworks 2023 daily as a job in the industrial/petrochemical field, and would like to make some custom touches to these to make my own unique part for my 2025 CTR I just got. Thanks!
Kikonio2
Enrique
Greenville, SC
2018 Civic Si Coupe
Could not find the link to the download of the stl file, would you mind sharing it?
