My dip stick smells like gas, should I change my oil asap? I don't know if that's what oil smells like cause I haven't done my own oil change yet but this might be the excuse I need to get it done. I heard gas can go past the piston rings if you beat on it without warming it up first but I don't do that so idk.
How many miles? DI engines dump a bit of fuel through the rings. That is why I like to keep my oil changes at around 3k intervals. Its cheap insurance.
It doesn't hurt to get a second opinion.
How many miles on your vehicle?
I've heard that changing the first "break-in oil" too early may or may not help.
Its always good practice to run the break in oil for a bit but once its over 1k miles everything will be pretty broken in.
I currently have 2650 miles on the car
Then you are good to go to change the oil. Depending on how cold it gets where you are I would go with a 5w-30. I can also help you with the oil if you are interested in amsoil products.
fredzy
PA
Sienna, GR86, TourX
DI has the inherent problem of fuel impinging into the oil on the cylinder walls, getting past the rings that way and accumulating. Especially if you don't get the car up to operating temp every trip, which can help keep water and volatiles out of the oil. Or this is how I remember it - I had this concern with 2 different vehicles years ago.
For me it improved with time, never noticing the gassy smell again after 10k miles or so. In one case it may have been the oil. 5000 miles on Subaru factory fill, 5000 miles on M1 full synthetic, both gassy per my nose and Blackstone. Then switched to M1 ESP, dilution was low, nose confirmed it and never noticed it again. Could have been the additives. Other vehicle I never had the oil tested, ran it on water-thin M1 AFE from the start per OEM recommendation and I noticed the gassy smell go away over time as well.
Anyway, use good oil and make sure to go for a longer trip from time to time and it will be OK. I smell some gas in the FL5. Will be running the M1 Extended Performance 0W20 (thickest 0W20, lots of additive package) and see how it goes.
I live in tulsa, oklahoma. It rarely ever gets below 32f, I've seen others using 5w-30 with no issues. I have also heard that ester based oil is good for protection and I do plan on tracking my car this spring. Which oil would you recommend though?
I use amsoil signature on all my cars. Running the 5w-30 on mine and I track it and 0 problems. Also the oil does not shear as quickly as a 0 weight. If you need help you can DM me.
cryptolime
Wilmington, NC
i lots of short trips as delivery driver and no oil dilution yet at 5k miles on factory fill. started to get darker in color around 4800 miles after some high rpm driving.
You won’t be able to tell the dilution just by color.
fredzy
PA
Sienna, GR86, TourX
I've been using M1 for years because it's cheap and easy to get and I figure it's good enough for me. I've always had in the back of my mind, ehh maybe I should switch to Amsoil?
Nowadays I have a good reason to go out of my way for better oil *cough* so after I read this post I went looking. I ended up doing the whole Amsoil preferred member thing and will run signature in the CTR and 86 and maybe the basic full synthetic in our normal vehicle(s) since it's not much more expensive than M1 at that point.
Anyhow it's funny because your avatar picture looks like a Mobil 1 advert
i know that. i'm judging oil dilution by smell of fuel and level. i was just adding more information. do with that what you will.
And I appreciate that, just that it might not be the most reliable way to tell. But its all good
Lol just the picture I got taken at Sebring which now that you point it out its hilarious. But I order amsoil by the bulk and I’m also a dealer.
cryptolime
Wilmington, NC
after changing out the factory fill, the dealership used valvoline synthetic. I now have a strong smell of gas on the dipstick and when smelling inside the oil fill hole. Is it okay to step up to 5w-30?
yes sir! Go ahead and swap out to 5w-30.
cryptolime
Wilmington, NC
drove about 3 to 4 hours yesterday and today and the oil level has gone down to where it was when i got my oil changed 1000 miles ago. right in the middle of the low and high points. was about 1 mm above the high point yesterday morning and it reeked. still smells a little bit like gas but much less so. so that's good news. at least it's not steadily going up. appears to be burning off. i did a high rpm pull last week and hit fuel cut so maybe it dumped a bunch of fuel into the cylinders when it cut spark. not sure how this ECU manages fuel cut/redline.
