Evox787
- Thread starter
- #1
I recently installed new wheels, tires, and lowering springs on my car. The previous alignment will be attached in a picture. I’m currently running 265/30/19 Continental DSW tires with 19x9.5 +50 wheels, paired with H&R lowering springs.
I was thinking of adjusting the alignment to get as close as possible to 1.5 degrees of camber in the front, with the toe set to 0 degrees as it is on stock. For the rear, I’d like to aim for around 1.5 degrees of camber, or as close as I can get to the 2 degrees I currently have. I plan to set the rear toe to about 0.4 degrees on each side.
I daily drive my car and I’m not trying to set any lap records, but I want to make sure my alignment setup will allow my tires to last. I rotate my tires every 5,000 miles, check tire pressure weekly, and run the OEM pressures.
Do you think this setup will work well for tire longevity? Any advice from the suspension gurus would be greatly appreciated!
