This is an interesting size to try. Wondering if the 9.5 wide OE wheel is wide enough to make 285/30/19 work? Curious minds want to know if it would work as wellHas anyone tried a 285/30/19 on stock wheel and suspension? Does it clear the suspension and fender?
Any rubbing on track?
John, iirc you had added sound deadening to wheel wells. Is there any chance the deadening material behind the liners pushed them away from the body and contributed to the rub you experienced on track? (Do you think a fully stock no-deadening setup would have the same issue?)Here are the results after 2 heavy track days at COTA in the Advanced group on 275/35 19 Pirelli PZero Corsa Track tires.
1) There was rubbing under high load, high g force sustained sweepers at COTA. Front Right did eat through the plastic wheel liner, but did not hit metal.
Conclusion is - 275/35 19's work, and for most all people not tracking the car you will not rub, but if you are tracking the car, you will rub, but it won't rub into the metal, just the plastic liner.
Great thread. I didn't need convincing, but here it is.... My opinion stands, 30 series is NOT the right size tire for this car. I don't need an ITS module, I need a 35 series.Can anyone else confirm this 275/35/19 works on track during cornering loads and maximum forces?
Here is why I'm concerned, you can see it's getting really close to the fender, and this is a stock car with only negative camber ball joints in front ---
Would appreciate anyone's feedback that has tracked the tires asap!
This is what the stock tire looks like under heavy compression on track in a right hander.![]()
It’s easy to think that almost 3° isn’t much, but that even wear is pretty impressive.Actually you make an excellent point, on track in Type R mode with the 35's zero issues, and tire wear is very even also. When I was on 30's it was too bumpy, and very difficult to manage even wear across the tire even with -3 camber in front. Road bumps, etc are a non issue. On my 4s I would have to run 41 PSI cold front 35-37 psi rear cold to ensure the side walls would not pinch. Currently I run 38 psi cold front and 32 cold rear on the Pzero Corsa's. Very smooth. Also wheel hop is eliminated by going a bigger diameter. The only negative is you lose a bit of gearing, but the extra sticky tires actually put down 2 second faster lap times than the cup 2's that were 265/30/19. Type R with the thicker side walls - it's like perfect.
Also... the touch bit more ground clearance is excellent. The wheels look more filled out, and no more scraping the nose.
Here are some photos on track under high g-forces
TireRack.com specs tab shows recommended wheel widths for each tire size. Recommendations may vary between tire brands.This is an interesting size to try. Wondering if the 9.5 wide OE wheel is wide enough to make 285/30/19 work? Curious minds want to know if it would work as well![]()
OK thanks that does make sense.I am on stock suspension, but I had modified my wheel liners with sound insulation so they were sagging. Others on completely stock did not have rubbing. But with springs, rub could be an issue. I personally don’t like lowered cars, due to decreased ground clearance, and most ruin the performance and ride if you don't match everything up perfectly and it's been thoroughly tested with exact dampeners, wheels, alignment, and total bushings etc.
If you don’t get springs you should be fine. If you find it slightly rubbing when steering wheel is turned all the way, you can use a heat gun and mold it back easy. It molds easy with light heat. Others on stock cars had no rubbing with 275/35 19 on stock rims. After you put the tires on, it filled the wheel arches so maybe if your purpose was aesthetics you may not need the springs.
Only the passenger side had some issues, it was sagging. Think stock you are fine. If not you can see like on driver side, it was barely touching under track load, so I just used a heat gun very light heat and molded it up.
I would not worry about this - it's cheap easy to replace wheel liners.
This guy had no rub, on track stock - I DM'd him
