It looks like you guys have the full contents of what you need despite the damaged boxes. Be sure to grab some zip ties that look like this! You'll need them to zip tie the hose that goes over the hot side intercooler pipe to secure the line away from the a/c compressor/serpentine belt! You'll also want some additional padding for the longer hose where it can rub against a sharp spot of the frame where it passes through the passenger side fender well area. I used DEI fire wrap with the velcro strap, and also some zip ties to hold it on really snug.
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! 51G8RrQYoAL._AC_UF894,1000_QL80_
If you can take some pictures for us it would be nice. I’m going to show it to my installer in 2 weeks.
This is the zip tied line on the hot side hose. You can see where it had initially started to rub before I fixed it.
I'll try to get a photo of the other, may prove to be kind of difficult.
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! PXL_20240119_134129364.MP
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! PXL_20240119_134106752
I just found a good reference for what I'm referring to with the frame. It's on my YouTube update video for the HEL cooler install. Fast forward to about 6:25 and you'll see what I'm talking about! Hope it helps!
Do we need to make the bracket modifications?
Yorkman1
DM
2024 Type-R #170001
@everyone. Did you get bolts to mount the cooler to the bracket? These are the only bolts I see. Yeah I know my box was destroyed so I’m guessing they went MIA. Upon opening up my oil filter adaptor the top edge is also smashed in.
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! imag
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! image
Here is everything I have from my damaged box. Let me know if I'm short something
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! PXL_20240310_015210081~2
Yorkman1
DM
2024 Type-R #170001
I do not see the bracket hardware. Should be at least 6 nuts and bolts that hold the brackets to the cooler. The manual for installation says use the hardware and show multiple nuts and bolts when you attach the plates to the cooler. I only see the 2 long hex heads with the multiple washers and lock nuts. Hopefully someone else can chime in when they open the box.
I'm not sure why they are still including those two plastic spacers. We don't use them with the aluminum crash bar.
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! PXL_20240310_015210081~3
Looks like what I have from my minor damaged box. If some can help verify contents, it would be great.
11th Gen Honda Civic Authorized Dealer + Group Buy Announcement! HEL Performance USA FL5 Oil Cooler Kit at Unity Performance! IMG_1686
Thanks. I reached out and Unity is taking care of it. Great customer support!
matttheazn
MO
my box also came damaged. I will have to check I have everything closely.
@Unity Performance Huzma, would you be able to post pictures of the contents so we can all check to see if we have everything needed for the installation?
