- Joined
- Oct 19, 2024
- Threads
- 10
- Messages
- 611
- Reaction score
- 547
- Location
- Ventura CA
- Vehicle(s)
- 2025 FL5, 2014 Chevy Suburban (wife), previous 2007 FA5
- Thread starter
- #16
Thanks,Your only real options are a used M3 or CT4-V Blackwing. The Blackwing will probably have to be used to fit within the $70k price point. Brand new, well-optioned CT4 BWs can rise up to near six-figures. CT5 BWs are very cool but way out of the budget you're throwing out. The only other downside from cost is they are very large and heavy cars (the CT4 is also quite heavy)- which is a pretty stark contrast from the FL5's philosophy of being astonishingly lightweight for a modern car.
An F80 M3 is a fantastic car. If you can find a clean, low-mileage option, that would be my recommendation. It's not going to have the finer inputs of the FL5 (e.g., shifter, steering), and it's an out-of-warranty BMW- but it's a higher tier car, for far less than you'd spend on a new Blackwing, and possibly less than you'd spend on an FL5 (but doubtful if you want a good one). The F8x generation of BMWs are truly "built different" and you won't find the litany of catastrophically expensive maintenance issues that plagued the older generations. The power will blow your fucking mind vs what you're used to with an older Honda.
You could conceivably find a used G80 M3 for ~$70k. I've never driven one but I'm tempted to go find out what it's like. The aesthetics have grown on me by a large margin since it was first introduced, and as far as I can tell it grants supercar-levels of performance in a very well put-together luxury package. The weight conversation will of course be relevant but I think categorically the G80 is just in a different class of car vs the FL5.
Another possible option is an Integra Type S. I realize there are a variety of philosophies on this board in particular that effectively shun the DE5, but if it's just the principal of not paying over MSRP to a southern California dealership, then you may be more likely to find a DE5 without a markup. If you're not philosophically opposed to it already.
Or just do what many, many others have done, and just buy it out of state.
I did not look at the weight for the CT4-V Blackwing... it is indeed nearly 700lb more than the CTR...
The 4BW is 8" longer than the CTR, yet rear leg room is 4" less, and trunk volume is less than half
so from practical standpoint, the CTR will be a much more practical car (and better gas milage)
as mentioned above never cared for BMW, did a quick compare of the M3 to the 4BW, seems that for my "requirements" above, the 4BW might be better, and it is cheaper than new M3, as is $70k is a bit of a stretch.
