CTR
strixauto.com
2023 Civic Type R, 2020 GX460
I'd like to share my first official modification with the community since I think it turned out pretty nice!
I always try to build my cars with an OEM+ style and modify it so that certain aspects look as factory as possible. I received my car in the winter and since it's always wet in Washington these types of mats are nearly a requirement on a daily driver.
11th Gen Honda Civic Custom DIY WeatherTech Type R Floor Mats PASS-SIDE-FINISHED
Initially I was looking at the Honda all weather floor mats but didn't like how they lacked the protection on the sides and that they were essentially standard Civic mats. The Honda accessory trunk liner is really nice and includes a Type R logo so I wanted to continue that look for the rest of the car. Here's a shot of the factory trunk liner for reference with the bottom right subwoofer area cut out (I used sharp scissors).
11th Gen Honda Civic Custom DIY WeatherTech Type R Floor Mats TRUNK-LINER
The actual floor mat modification involves purchasing a set of 22-23 Honda Civic FloorLiners from WeatherTech. You will want to buy the non-USB style.
https://www.weathertech.com/honda/2023/civic/floorliner-digitalfit/civic-2nd-row-usb-ports-11/no/
The only part I hated about these floor mats is the ugly WeatherTech logo so I figured there was a chance someone made a direct replacement sticker that could match the car a bit more.
After quite a bit of searching this was the only place I could find that sold stickers in the CORRECT Type R logo:
https://strixauto.com/products/type-r-weathertech-floor-liner-floor-mat-stickers
Others didn't have the T and the Y connected like the trunk mat.
11th Gen Honda Civic Custom DIY WeatherTech Type R Floor Mats PASS-TYPE-R-MAT
You can get a fingernail/plastic tool under an edge and the WeatherTech stickers peel right off. I did bring the mats inside the house so they were warmer when applying the sticker but you may want to use a hairdryer on the mat/sticker to make sure the adhesive bonds well. Clean the sticker area with the provided alcohol wipes and then try your best to line up the new stickers before applying.
11th Gen Honda Civic Custom DIY WeatherTech Type R Floor Mats DRIVER-SIDE-FINISHED
I've received multiple compliments about how clean it turned out. While the liners are not perfect I feel that they are better than the factory ones and don't completely change the look of the interior like the TuxMats.
qwertypop
VA
2006 S2000, 2022 Sienna, 2023 FL5 Type R
Was looking for something exactly like this. Appreciate the post!
CTR
CTR
strixauto.com
I don't think they will be making another version as this fits all 22-23 Civics. It's just with the red carpet you can see areas where they don't line up with the side plastic trim.
11th Gen Honda Civic Custom DIY WeatherTech Type R Floor Mats SIDE-ALIGNMENT-FLOOR-MAT
As you can see in this photo the top corner hits on the plastic and then tapers down at a weird angle towards the seat. Maybe this was the only way to make the shape and have the high coverage on the front? This bugs me a little bit especially if it starts to scuff that hard plastic from the two materials rubbing. Maybe it's by design since that is where you are most likely to touch your feet?
TDC50
Long Island NY
‘23 Type R, ‘24 GR86
I have WeatherTechs as well and like them but be aware on the driver dead pedal it doesn’t cover enough of the carpet. I added a little low adhesion clear vinyl over the carpet in that area because it started to get dirty
CTR
CTR
strixauto.com
Good call! I’m hoping someone releases a metal dead pedal soon that maybe covers part of that. The pedals are so far over they could totally expand it over that little bit. In the meantime I might do something similar to what you described.
Thanks for sharing those stickers! Ordered some up.
LaFlamaBlanca
Arizona
FL5 Type R
I ordered some of those stickers too, thanks! I was going to maybe try these before ordering weathertechs and see if sticker fits these. It seems like they line up better with interior trim and are cheaper, good reviews: OEDRO Floor Mats Compatible for 2022-2023 Honda Civic Sedan/Hatchback (Not Fit 2rd Row with USB Port), Black TPE All-Weather Floor Liners https://a.co/d/4C8qQE8
machimself
Michael
Let us know how this pans out for you. I’m beginning to not care much for the OEM all-weather mats and may do this for the next PNW winter.
LaFlamaBlanca
Arizona
FL5 Type R
thx for this. I went with this amazon set of mats and bought the stickers you bought. These also fit perfect with the stickers and fitment of these mats shockingly perfect: SMARTLINER Custom Fit All Weather Black 2 Row Floor Mat Liner Set Compatible with 2022-2023 Honda Civic (Does not Fit with 2nd Row USB Ports) https://a.co/d/96sUuOq
11th Gen Honda Civic Custom DIY WeatherTech Type R Floor Mats 4B7AC092-D5C2-45A3-99F3-89BC21BDCE95
  • Like
Reactions: CTR
Estoril4
Has anyone tried the tux mats yet?
CTR
CTR
strixauto.com
TuxMats are popular and nice but I didn’t like how they looked so out of place in the interior. Their “scale” type texture looks kinda weird IMO which is why I went with WeatherTech and changed the sticker.
Fresh
Northeast Ohio
I’ve always used WeatherTech but have heard the clutch and/or accelerator may not fully depress. Can you confirm they can fully depress?
CTR
CTR
strixauto.com
No issues at all with WeatherTech. TuxMats are the ones that are too close to the pedals causing interference.
Tuxmats work fine. They cover almost everything. Pedal when fully depressed does touch but it functions fine. Have 18k miles on mine and once cleaned after winter use look Brand New.
