DIY exhaust upgrade ...
Zone47
Joe
NE Ohio
I never cared for the valved exhaust and the triple uneven exhaust design, so it was time to change it out. I know Honda has to pass Federal sound levels but it just doesn't look/sound very good.
This is the monstrosity that lurks under the Honda, all 26 pounds worth. The main exhaust pipe is only 2.5" OD.
Of course it's smart to save the old stuff as it adds value to the car whenever you sell it!
After some research I ordered some parts from Summit Racing and went with the Flow master chambered and stainless muffler. It's 3" in and twin 2.5" out and weighs 8 pounds. I figure the 3" input gives me some headroom in case I want to upgrade the rest of the exhaust later if needed.
Before installing the new muffler, I fired the car up. The engine tone straight out of the open pipe isn't any louder IMO than with the stock muffler and valve being open. The two resonators tone the noise down more than I expected.
This shaves off nearly 20 pounds of excess weight.
11th Gen Honda Civic DIY exhaust upgrade ... DSC_0230
Below is the final result. I left it tack welded and clamped to test drive first in case I want make any changes. I might raise it up about an inch. It has a nice deep tone but isn't too loud inside the cabin. I can hear the burble in between gears, I love it! The exhaust tips are Jones stainless steel. The car finally sounds like it looks, and for around $220!
11th Gen Honda Civic DIY exhaust upgrade ... DSC_0249a
Zone47
Zone47
Joe
NE Ohio
Looks like a great alternative. Would you have the part number for this? Thank you in advance.
It is FLO-8430152 I bought it from Summit Racing. It's a bit of work to fab up a curved pipe from the cut point to the new muffler... it needs about a 3" rise and into the muffler. You can probably have someone fab one up for you too for a reasonable price.
11th Gen Honda Civic DIY exhaust upgrade ... FM muffler
11th Gen Honda Civic DIY exhaust upgrade ... Tips
Zone47
Zone47
Joe
NE Ohio
Looks good! I don't think I have heard one of these cars with a chambered muffler. Please post a sound clip if you can.
I attempted to make some sound clips/videos but the mic on my Hero 4 Go Pro isn't doing it justice... wind noise and all that. It's not very loud because of the two resonators are still in line, but still much better than stock. I'll try another camera or maybe just a recorder with a good mic and maybe do a drive by if the rain lets up.
1904_CWFL5
Thank you for the helpful information. I’ve had Super 10s on a previous car. Can’t wait for some sound clips.
Zone47
Zone47
Joe
NE Ohio
Sorry this took so long.
I'm not really a sound clip kind of guy but I did the best I could by taping a Hero 4 on my back bumper and running down the road. Headphones might give you more of the true sound.
So this exhaust isn't very loud but you can at least hear it inside and outside the car and it sounds good. Cutting out the front resonator would spice things up dramatically! It does seem to breath better and runs stronger than it did with the stock system.
So to be fair, the pro systems offered for the CTR are going to be the way to go if money is no object. I saw a nice titanium system that deleted the resonators and with the valve closed sounded healthy, yet with the valve open it sounded like a race car ... so maybe that is a better option for some.
Nice work, man! Very clever and inexpensive alternative to the pricy aftermarket systems. Sounds good too!
Did you add any hangers in place of the ones on the original mufflers?
Zone47
Zone47
Joe
NE Ohio
Thanks, Yeah that was the hard part, I have a temporary hanger until I can get some rods welded to the muffler to use the factory rubber mounts. But it's pretty light, so no problem overall. So that is the down side. If you aren't a welder or have access to one, an aftermarket is more plug and play if you know what you want, but $$$.
I actually have a little Hobart 140 mig welder, but I have only ever welded mild steel. From what I understand, welding stainless is a whole different ballgame requiring different gas and lots of practice.
tezzasaurusrex
Terence
Nice! I keep finding myself brain storming ways of modifying the stock exhaust to similar effect, mainly increase pipe diameter throughout the entire system to 70mm but retain the OEM muffler section perhaps deleting the centre exit muffler to increase the sound at WOT (valve open).
Do you have any photos of how you joined the flow master muffler to the rest of the system?
Zone47
Zone47
Joe
NE Ohio
Yeah, it's not easy.
