DIY Oil Change
1st oil change yesterday at 5K miles. Some things to note:
1.) #3 Phillips head drivers work fine in the 4 screws. No issues and I've used #3 Phillips for a decade on a CRV (screws still like new). I put some Permatex anti-seize on the rear threads before reinstalling, since there was more friction than I liked.
I used a wide blade driver in the 1/4 turn fasteners.
2.) 5-1/2 quarts of 5W-30 topped up the level per the dip stick (which sucks as most agree).
3.) I installed a Mishimoto PCV catch can at around 1000 miles. It had roughly 2 tablespoons of oil in it.
Mishimoto uses an unusual hex size screw between the bracket and can, so I swapped in conventional socket head cap screws (M4 x 8mm) which have a common 3 mm wrench size.
4.) I have an ancient set of ramps, and some wood plank pre-ramps, so no jacking. I saw the front center jack point, and it's way under there.
5.) OEM filter and new crush washer.
All is good,
Cheers
dpark1986
Daniel
Brentwood TN
S2000
All is good,
Cheers
I also did my first oil change and felt unwanted friction on two of the four screws when unscrewed/screwed. I saw some metal shavings on the threads so I will probably put some anti seize on them too.
zumbooruk
Ventura CA
https://www.valvomax.com
Also available on Amazon (about the same price, but free shipping with prime, and 5% off with prime Visa)
