First FL5 oil change mileage?
AspecR
Stefan
I'm hoping we are allowed to use any Honda dealer to service the free oil change, not just the dealer where it was purchased (in which case is 100 miles from me). :(
I'd like to use Mobil 1 but need to see what this car requires as far as API service codes.
Yes with Honda Service Pass you can go to any Honda dealership. You can use pretty much any API SN rated oil
William
2024 Honda Civic Type R
900 miles is too early for an oil change. The oil placed in the car at the factory has a special blend in for break in. Changing it too early WILL not work in your favor. Best to wait til the maintenance minder gets to at least 40%
But what if that 900 miles was over a years time? I for one work from home so putting miles on my CTR is rare, into my 5th month of ownership and just crossed 600 miles.
AspecR
Stefan
If it’s over a year then you should definitely change it. Oil should be changed at least once a year regardless of mileage driven
madbikes
SF Bay Area
The maintenance reminder will adjust the fact that you don't drive much.
For example, you drove 5,000 miles over 8 months. Then you decide to enjoy yourself somewhere nice for the rest of the year. The maintenance minder should be like 10 percent or so and ask you to service the car by the time you are back.
Another scenario. Say you did your first service that has an oil change, but the weather is has been lousy for the next 6 months. Then you feel like to take it for a nice drive in summer. The maintenance minder may read 50 percent oil life you turn it on.
Whatever the case it is, regardless of how little miles you put over a year, you should change your oil once a year.
egxflash
CA
2024 Integra Type-S
I noticed this on mine. I have 1,600 miles on my DE5 now after 6 months of ownership and the MM is showing 60%.
If it was based purely on mileage, this puts me on track at 4,000 mi OCI. If purely based on time, I'd be at 3,200 so we'll see.
Either way, I'm planning on doing my first oil change at the year mark and no later.
GoSailin
Josh
Kentucky
2025 Honda Civic Type R
I've found a lot of good info on the forums about the first oil change etc. It's been very helpful in trying to figure out when to do my first oil change.
Personally, I am in the habit of doing the first oil change around 1000-1500miles or so. My most recent new cars were 2020 Subaru WRX and 2023 Camaro SS 1LE. Apparently that is not as important with the Type R from what I have gathered. I would still like to get the oil changed before 5k miles though. I can definitely understand why there is so much discussion on this topic. I just wanted to add some input on what my local dealers telling me on my 2025 Type R..
Apparently the 2 year service plan is no longer a thing for 2025 models. The newest model year only has 1 year and 1 service free. They said the absolute EARLIEST I can bring mine in is when the oil light says 30%. I'm currently around 2800 miles (80% oil life) as a daily driver, 90% highway miles with no traffic and very few stop lights. It does see a lot of cold starts now though with temps getting as low as 15 degrees F (winter weather now). I try to baby it in the mornings until it warms up a bit. I read somewhere that another forum post said their dealership used an oil blend, so I wanted to check what my dealership used. They said they use 0-20 full synthetic.
After I get that free service and 1st oil change knocked out, I will continue what I have always done in the past and do the maintenance myself. Running Mobile1 full synthetic 0-20 every 5000 miles. Haven't checked yet, but hopefully Mobile1 sells that OEM weight.
Zone47
Joe
NE Ohio
I don't think I'm going to wait that long. I have about 3,800 miles and I'll wait until spring, although I'm not driving the car in the winter.
I think I'll just do my own oil change rather than have the shop guys flog it around the block a few times. (and they do). Mine had 7 miles in the showroom and then 15 miles out in the parking lot when I left the dealership.
Zpeedster M
New York
2023 Type R FL5
Mine had 4 miles on odo, picked up at 14 :mad:
Cap
Earth
AP1 S2000, B7 S4 Avant
Brought mine in to the dealer for its first oil change @ 3,6xx miles (40% oil life). They tried to talk me out of changing the oil that early and wanted me to come back when it was at 5,000 miles, saying its special oil etc. if I change it now it can cause problems later.
I said no, change it today, I'm good. They print out the service form and include this same message about potentially causing problems later - and want me to initial it. I said I'm not signing that ridiculousness - it's not like I'm asking them to change it with 50 miles on the odo.
Wacky world.
TchnoZ33
Zaid
Indiana
Personally I think it’s wacky people think this much about the oil lol
nawfoo
Banned
Banned
K
Lost Wages
Integra Si
They think they are too good for OEM oil and want to sound badass changing the oil right away. I'll change mine when the light comes on. When the NISMO/HOMO GT-Type R comes out I might change it every 4 miles.
cyirush
Craig
Long Beach CA
2005 Lotus Elise; 1968 MGB; 2016 Nissan Leaf
That is absolutely correct as @AspecR says. Leave the original break-in oil in the car for awhile. The original oil has additives that basically continue to polish and fortify the cylinders beyond the factory machining and polishing. Consider it the final step in the engine polishing process. Anywhere from 3k-5k miles is probably good, but don’t keep it in there beyond about a year is good advice. After that, change your car’s oil every day if you like. ? Why don’t the dealership shops explain this stuff? It’s pretty important.
Question for you and @AspecR - is there any documentation from Honda about the factory fill being special break-in oil? I can’t see it in the owner’s manual.
Or about how long to keep it in the engine?
I’m a new owner with ~1,500 miles on the engine and wondering if I should change it (there are other threads on here saying to do this because there’s break-in metal and assembly lubricants showing up in oil analysis of new engines like mine).
Thanks!
AspecR
Stefan
Thanks!
Official documentation nope, The owner's manual for the FL5 Type R is really just a generic civic hatchback manual. So it gives no details on when you're oil changes should be done. If you follow the manual religiously it will tell you to wait til the maintenace minder is in the right percentage range which isn't bad but not recommended for an enthusiast car like the FL5 that generally gets driven harder and modified more often than not. It really is based on preference when it comes to these engines, personally I changed mine at 4.5k miles but I've had clients change theres after 500 miles, 1500 miles and others that waited til their oil life got to 20% which generally happens at alot more than 5k miles.
How you drive it and how much regular maintenance you do will have a much larger impact on your engine than if you did your first oil change 1.5k miles vs. 5k miles.
cyirush
Craig
Long Beach CA
How you drive it and how much regular maintenance you do will have a much larger impact on your engine than if you did your oil change 1.5k miles vs. 5k miles.
Thanks for your reply!
I’m finding the lack of info from the factory frustrating.
Did you hear about the break-in oil from someone at Honda?
Per your original post, sounds like an early change on a new engine (1500 miles) would not be advisable as the special factory fill is still doing its break-in work?
