Does the FL5 get free complimentary maintenance?
ThunderPigeon
Long Island
my understanding is that changing the oil yourself, or taking it to a non-Honda mechanic should not void the warranty.
I fully intend to change the oil myself, using Pennzoil Platinum Plus 0w-20, Fram ultra synthetic oil filter, and Votex quick drain valve
https://votex-us.com
better quality oil and parts, I know I'll do it right, cheaper, and faster (nearest dealership is 15-20 miles out, and I hate waiting)
I'll keep detailed records and receipts, and add a service record at the Honda website:
https://mygarage.honda.com/s/service-records
btw, my understanding is that the Honda OEM oil filter is a re-labeled cheapest Fram filter.
Add any maintenance you do to my garage on the Honda website. Anything the dealer does shows up there as well.
Just hope it doesn't get lost again. They switched from a different service not long ago and all my maintenance records on my Pilot did not transfer over.
Nothing
2023 CW FL5 #5044
Is this on dreamshop? I just keep a google spreadsheet, is my garage any more legit?
Zpeedster M
New York
2023 Type R FL5
Blasphemy, Honda owners swear by OEM oil filter, made by the Honda Gods...... :bow:
ThunderPigeon
Long Island
Not sure if the my garage entries show up on a Carfax maintenance reports. Would be something worth checking out.
JCZ5
Philly / NYC
Do you really have to wait till the 10K mark though? My understanding was you can take it into Honda sooner. Basically, they will just do one service free for MY25, regardless when you want to do it.
ThunderPigeon
Long Island
From what I have seen, it depends on the dealer. But 15% is when they are supposed to do it. I hit 15% after ~5800 miles.
When a dealer agrees to change your oil depends on the dealer. Some take a liberal posture while others are more conservative. The maintenance minder notification is triggered by a number of factors. For example, if you drive 30,000 miles in one year, the maintenance minder will trigger multiple times within a 12-month period. Conversely, if you drive 900 miles in a 12-month period, the maintenance minder notification, will in most cases, come on right around the 12-month mark.
Other than the steering rack recall, I'm not letting the dealer touch my car.
Dealers often have low skilled techs doing the routine stuff. I've heard several horror stories from friends and neighbors.
I have decades of auto wrenching experience without mistakes. And I get to chose the oil I want.
zumbooruk
Ventura CA
I concur. I had one experience with a Honda dealership for the second gear synchro recall for my '07 FA5 Civic Si
they put the last gear in reverse, and it was digging into the transmission case. I only discovered it when clutch started slipping (springs got weak? since there was plenty of clutch material) about 100k miles later
anyway, since it was way out of warranty, I took it to a non-Honda mechanic who said that it was a few thousands of an inch from boring all way way through the transmission case. he installed a new case, rebuilt the transmission correctly, and replaced the clutch with an Exedy stage 1 clutch and flywheel kit.
Robimplicit
Civic type R
I feet the same way and did the first oil change on my Type R at 700 miles and the second at 5085 miles to avoid contact with the dealer.
My car had no steering symptoms, and I waited and waited to take it to the local Honda dealer for the EPS Steering Gearbox recall. I finally a few months ago after reading that the procedure had been simplified. I also spoke with one of the service advisors who said they were doing several of these recalls every day with no problem. So, I felt more comfortable taking it in.
The car seemed fine after the recall service. We had a short vacation scheduled a week later that involved a 500 mile round trip. No problem on the trip but a day or two after returning I noticed by chance that one of the lug nuts was missing from the right front wheel. I checked the others on that wheel and all were loose.
Thinking about how this could have happened, I realized it had to have been the recall service; I had seen video of the service that involved removing the right front wheel. I assume the tech failed to torque the lug nuts when re-installing that wheel.
I wound up replacing the lug nut and tightening all to spec. About a week later I went back to the Honda dealer and spoke with the same advisor about what had happened. I said I assumed that all the techs were busy and under pressure to pump out as much work as possible. But, this was a dangerous mistake that could have cause a bad accident. He agreed. He identified who had done the work and said he would talk to the technician about the mistake. I didn't want to get the person fired and didn't take it any further. But, I did want the tech to know what had happened and be more careful, regardless of how busy it got. I realize my wife and I were lucky that nothing terrible happened at 80 mph on the highway, and I'll be checking the lugs more often.
