Robert.C
- Joined
- Jul 25, 2022
- Threads
- 3
- Messages
- 548
- Reaction score
- 656
- Location
- San Diego, CA
- Vehicle(s)
- AP1, DC2-R
+38? They look really far out.Nope, just the wheels.
My mancould be wrong tho.
Correct:I think the 19's are ET45 offset...
could be wrong tho.
Are these different offset from stock to get that flush fit or is it just the angle?Nice setup!
Still at stock height but we went with the TS-5s from Titan-7, also in Techna Bronze. (19")
I'm glad I'm not the only one that thought the same. They seem to be way out on the corners for a +45.Are these different offset from stock to get that flush fit or is it just the angle?
The factory offset is different... a whopping 60mm. In this case, less is more. They are 15mm out further than stock.Are these different offset from stock to get that flush fit or is it just the angle?
Yeah this look is much better than stock. I'm a little worried about additional road debris getting kicked onto the paint but just a typical sacrifice for aesthetics.The factory offset is different... a whopping 60mm. In this case, less is more. They are 15mm out further than stock.
Fitted on OEM tire or did you go a different size?I will include a few other photos below. They wheels are about 6lbs lighter than factory each and the Titan-7 lugnuts I am using are 1.5lbs lighter than the factory set (total). I can't say that I have driven the car hard enough since installing them to feel anything but I think it is fair to assume that there are notable benefits there with such a large loss of unsprung weight.
Shameless plug: We are a Titan-7 stocking dealer. This is one of many examples of how we truly believe in and use the parts we sell.
https://www.twostepperformance.com/search?vendor/Titan7
I ended up sticking with the OEM size. I was interested in a wider tire but couldn't find anything in stock locally that worked for me.Fitted on OEM tire or did you go a different size?
