FL5 Front Camber (Strut Pin Removal)
tezzasaurusrex
tezzasaurusrex
Terence
Wunderladen Front Strut Locks Link
What are your thoughts about this product from Wunderland Racing? I like the idea that it provides some insurance from the bolts sliding around a bit after a bump (ie rumble strips/curbing on a track), but is that even a possibility with the correct torque applied?
I've never seen strut tops slide when torqued to spec, by the time something of such high force would shift the strut top out of position I'd say you've done damage to other components so having it shift might've saved something else from breaking.
johnloov
John
OK, I just confirmed that my front wheels are towed in 1/16 of an inch after removing the pins. I’m not sure what the OEM spec was but it’s very little.
tezzasaurusrex
tezzasaurusrex
Terence
OEM can be quite varied. I've seen anywhere between -2mm to +1mm. I recommend 0 to +1mm for tyre longevity
johnloov
John
Many thanks for the help! Worked great!
I taped quarter - increments. I believe I'm close to zero and will also try another quarter turn for slight toe out.
Have you noticed much better performance with zero toe vs toe out?
11th Gen Honda Civic FL5 Front Camber (Strut Pin Removal) tempImage3ltNfO
11th Gen Honda Civic FL5 Front Camber (Strut Pin Removal) tempImageQaXZ2s
11th Gen Honda Civic FL5 Front Camber (Strut Pin Removal) tempImageZOmGoM
11th Gen Honda Civic FL5 Front Camber (Strut Pin Removal) tempImagemTOcgz
11th Gen Honda Civic FL5 Front Camber (Strut Pin Removal) tempImageoE7ziQ
johnloov
John
If I had to get a track alignment on the stock suspension with the pins out, what are the exact settings you would recommend for all 4 wheels?
Would it help? or just Toe at zero or positive is all I need?
johnloov
John
Went for some extensive road testing, and the Toe out on the stock suspension with the pins out, is truly amazing.
It doesn't tram line, it drives straight, while being more willing to turn in easier, and feels much lighter in the hands.
I did a full half turn of the tie rods on both sides.
I'll be testing it on Laguna Seca tomorrow.
Highly recommend!
NorCal
EG6, S2K, Suburban, CB650R
Checking in on updates for cars putting in hard duty with pins removed.
Planning to do mine soon sometime after dropping off for steering recall
nttran98
Nhan
2026 FL5
Highly recommend!
Can you post the alignment spec.
johnloov
John
This is my alignment with me driver sitting - so that's why you'll see camber a bit different on drivers side - I was running on stock 265/30/19 rims and tires, and now I've simply put bigger tires PZERO CORSAs 275/35/19
11th Gen Honda Civic FL5 Front Camber (Strut Pin Removal) 1789600304436-q2
11th Gen Honda Civic FL5 Front Camber (Strut Pin Removal) 1789600321703-5l
