FL5 Lowering Springs
Superhatch
Jacob
Wisconsin
Eibach Pro-Kit
+15mm Bonoss spacers
No camber adjustment yet.
Will update with added pics after alignment and settling.
Might go to +10mm in the rear.
Pics took same day as install. Hoping rears settle a little bit more but overall I'm surprised at the drop, I was expecting less. I'd probably go H&R if I did it again. Comfort & sport feel like stock, +R feels better. HUGE PITA for install. Drivers side took me about 3-4h on it's own, everything else was pretty easy. Suggest two people as moving the steering wheel helped getting the drivers side to seat. Remove your axle nut to help with axle popping out, I didn't and damaged one of my axle seals so I get to do it all over again this weekend.
11th Gen Honda Civic FL5 Lowering Springs IMG_6165
11th Gen Honda Civic FL5 Lowering Springs IMG_6161
11th Gen Honda Civic FL5 Lowering Springs IMG_6162
11th Gen Honda Civic FL5 Lowering Springs IMG_6163
11th Gen Honda Civic FL5 Lowering Springs IMG_6158
11th Gen Honda Civic FL5 Lowering Springs IMG_6159
11th Gen Honda Civic FL5 Lowering Springs IMG_6164
rondre3000
San Diego, CA
I ended up going with H&R because I wanted just a slight drop. I like the way the car looks now with some 20mm spacers all around. The ride quality feels about the same as stock, maybe slightly less harsh over rough roads. My only complaint is the springs are slightly uneven. I took measurements prior to my install and a few months after.
These measurements are from the top of the stock wheel rim to the bottom of the fender.
Stock measurements:
3 7/8” - Front Driver side
3 7/8” - Front Passenger side
3 6/8” - Rear Driver side
3 6/8” - Rear Passenger side
With H&R measurements:
3 1/8” - Front Driver side
3 2/8” - Front Passenger side
2 15/16” - Rear Driver side
3 1/16” - Rear Passenger side
So the driver side is 1/8” lower than the passenger side, and the rear is 3/16” lower than the front (which is 1/16” more than when it was stock). Is that within normal tolerances or did I get really unlucky with my springs? Had them professionally installed by the best shop in town.
Lemme guess. You typically drive without a passenger, right? Every car I've lowered (5) has always started with the passenger side of the car higher than the driver side.
Robo7
Robo7
Lemme guess. You typically drive without a passenger, right? Every car I've lowered (5) has always started with the passenger side of the car lower than the driver side.
Yes I rarely have a passenger. But in my case the passenger side is higher than the driver side.
rondre3000
San Diego, CA
My bad...that totally came out all wrong. My passenger sides ALWAYS start out HIGHER than the drivers side. Will edit my OG post.
Robo7
Robo7
Interesting. Have they leveled out over time?
Superhatch
Jacob
Wisconsin
That's funny because I just noticed the same thing on my recent Eibach install. Drivers side is lower than the passenger side by about 1/4". You can see it in the pics above, but it's also lower than I expected which is what has me a bit worried.
jpindustrie
JP
2025 SG FL5
Researching springs and debating between the Eibach's vs the Swift's, I value more track performance than street compliance which be the one to go with ?
Also I found that with lowered cars usually call for a 'roll center correction' kit to really compensate for the drop (when I installed these new joints onto a lowered STI it made it handle better), is that something people do for the FL5 Type R ?
Thanks
johnny_F8
Houston, TX
reading post 37 and 38 makes me feel better. Just noticed this as well. Eibach pro kit. Driver side rear is lower but then again, less than 50 miles of driven after install.
Superhatch
Jacob
Wisconsin
I remember watching a vid from an Eibach engineer who said that the springs don't settle as much as the bushings and rubber in the suspension adjust to the lower positions of everything.
This makes sense as to why the drivers side is lower than everything else as those bushings have been adjusting to our weight and the other ones haven't had the time and mileage to 'wear in'.
I've normally put suspension on a used car and the bushings have moved from their factory position already due to time and so the height of the corners is more even right after install.
weaponx9x
marcos
miami
nissan sentra
Any updates? I know it’s an old post but I’m curious on everyone’s experience with your current set up. I’m on the market for lowring springs.
Superhatch
Jacob
Wisconsin
I'm still happy with my setup. The rest of the springs/bushings/whatever settled out on my Eibach's and the setup looks great. I snapped some pics on my winter 18s pre-winter. No regrets.
11th Gen Honda Civic FL5 Lowering Springs 1769646845672-lk
11th Gen Honda Civic FL5 Lowering Springs 1769646805010-mo
weaponx9x
marcos
miami
nissan sentra
Damn that stance looks nice!!!!
No rubbing of bottoming out? How’s the ride with passengers? I got the same color waiting for it to come first week of Feb is delivery date.
Superhatch
Jacob
Wisconsin
No issues at all with the stock wheels or with the winter setup (18s). I sometimes have 3-4 people in the car when driving wife/nephew/brother, and no issues.
