Got carried away bidding at a salvage auction
Ksmart
Kevin
Utah
As you can imagine, I got caught up in the moment and long story short I got me a 2023 FL5. The main surprise when it showed up was a hole in the trans case (looks like the CV axle hit it)
The firewall / wheel well got damaged as well. Other than suspension parts and a transmission, body wise all it needs is the driver fender and some work on the driver door. The front bumper got a small bit of damage but not enough to replace it.
My goal is to have it registered and back on the road by the end of April.
Ps nice to meet you all!
11th Gen Honda Civic Got carried away bidding at a salvage auction 9484c97a-6e22-4f22-ada0-31244908174a~3
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250301_185152515
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250222_003723674
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250221_233036806
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250221_233028353
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250221_234113343.MP
I look forward to seeing your progress. Are you planning to do anything in particular with it. I think if I bought a wrecked FL5 I’d make it a track monster. I mean…while I have things taken apart, I may as well make some enhancements. ?
Nice find. Interesting they totaled it with so little damage. Unless they total vehicles from firewall damage. I'm impressed how localized the damage is. I guess it hit a curb.
Nanook
JP
Chester, VA
Oh that’s awesome. I can’t wait to watch the progress on this.
Ksmart
Ksmart
Kevin
Utah
Plan is just to daily drive it and enjoy canyon drives. Weather is decent today so I'm going to try and get the suspension together and get it off the trailer. I think most insurance companies won't touch firewall damage. I get that if the frame horn pushed into the firewall or something like that, but in this case the wheel hit it and it looked very savable. Time will tell but I'm sure it will come together fine. The PO said someone hit into them and they ran off the road into a corn field. Funny enough they took off their intake and exhaust when it went to auction so I'm trying to buy those. She is looking for the second key as well to send me so that would be cool. I'll share the progress later today with you all.
Ksmart
Ksmart
Kevin
Utah
I had a fairly productive couple of hours this afternoon. I was able to JB weld the hole in the trans, install the new knuckle and axle, and use an old damaged wheel I had from my FK8 to get this thing sitting back on all four. Also started it up and moved it about a foot on the trailer. The caliper got pretty scraped up, and the shock got a little damage but I'll leave that for now. Upper strut mount is all clean and straight. Not sure if the LCA is bent yet, looks ok but it may be. Hopefully the JB weld holds up enough to drive the car around the neighborhood and move it around while I work on everything.
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250308_231820599
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250308_174236872
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250308_231831941
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250309_005522704.MP
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250309_004637213
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250309_004631366
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250309_004647327
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250308_231845764.MP
jcm
LA
2025 SGP FL5
probably a salvage goldmine, let us know if slapping AWD on this thing is something you consider... kekw
will keep an eye out for the updates.
Ksmart
Ksmart
Kevin
Utah
Not really interested in AWD swap. Id kswap a Subaru before I ever AWD swap a Honda. Hopefully I can get it off the trailer and drive it up the street this week!
Ksmart
Ksmart
Kevin
Utah
I was able to drive the car around the block! Not that this was a good test drive, but it was still exciting. Funny I had never even sat in an FL5 before buying this one.
Anyway, JB weld held up to the short drive, I shifted through 1-3 gears. Obviously alignment is way off still. Once on the ground I could tell pretty obviously that the left front wheel was sitting further back in the wheel well. Initial measurements comparing pass side indicate LCA so that has been ordered.
Also re set the bead on one rear tire, couldn't get the front on so I had to put another damaged FK8 wheel on the pass front. Hoarding pays off sometimes ha. Slow and steady I guess. All one step closer to registration and daily driving!
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250310_223837163
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250310_225038827
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250310_223514758
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250310_223503639
11th Gen Honda Civic Got carried away bidding at a salvage auction PXL_20250310_223815349.MP
arcticdc5
William
I'm guessing this sold for $28k at insurance auction?
arcticdc5
William
Lows 20s. I'm guessing repairs will be around 10k or so.
Not bad at all really. Someone could fix this and still have a decent FL5 for under $35k. Whats the odometer reading? Extremely lucky with no airbag deployments as those get costly especially with the dash and sending off the SRS module for a reset.
