Honda Hack / Root: 11th Gen - Work In Progress Discoveries
Jamieden
James
2022 Honda Civic Touring
Woah! By sheer accident, I found this menu. From the self diagnostics menu, I held “Back + Power + Previous”
Sorry, from the Detailed Information and Setting menu
Jamieden
James
I’m going to make a flow chart with all possible combinations for button presses in all the menu options. I’ll post my findings when I figure it all out
Jamieden
James
Brute forcing the menu!
Someone’s gotta do it. Might as well do it myself. There’s obviously more to the menu than we thought if I found a menu that wasn’t on this thread by mistake
iLLNESS
Ontario, Canada
1993 EG k20a2, 2017 Civic Touring
I think there might be something with hidden buttons on screen as well.
It’s also very possible that the adb functions are locked down by a USB key of some sort.
Jamieden
James
It would show up as a device if it was plugged into then. The ADB mode just provides no power to the USB, meaning no data. I could probably probe the data+ and data- pins on the USB port to see if any data voltage is detected. If it is, then it needs power
Jamieden
James
Hidden buttons? Can you give me an example?
eric__
eric__
eric
Indiana
2022 Honda Civic Touring (Meteorite Gray)
this is for the 9”display. It’s nowhere near complete
this is good work, nice to see all the options granted by different key presses. I’m certain there’s got to be one more combination we are missing to unlock ADB.
but I also know that Panasonic has taken a larger stance on cybersecurity in their radios which explains why they are locked down way tighter. In more modern cars with tons of computers, you don’t want the radio being the weak link into the CANBus into hacking the whole car.
Jamieden
James
I learned something. Android based head units have a specific way for testing applications and entering ADB mode. Apparently, using another Android device, you can tunnel in using the AOA (Android Open Accessory) protocol. I’m hoping I can use my rooted Android device to tunnel into the head unit
Jamieden
James
HAHAHAHAHA!!! I figured it out!! Go to general settings -> system -> about -> tap the build number 10 times. You’ll now have the developer menu available!!!
Jamieden
James
I’m now going to attempt to use my rooted android phone with a terminal to initiate an ADB connection
Lol. Yep that works on all Android devices
Bunhyung
Benjamin
Maine, USA.
'22 CBP ST
While you're in there, scroll down to Window animation scale, Transition animation scale, and Animator duration scale and set them all to animation off. This will make inter-screen transitions faster and snappier.
You may also check the settings in the Default USB configuration menu to see if any of the options available are useful.
Lastly, I don't know if the setting called "Force allow apps on external" helps the cause.
