I made a 3D printable model of the OEM FL5 shift boot collar
honman
Rochester
2024 FL5 Type R
After upgrading my FL5 with a Billetworkz weighted shift knob and alcantara boot I wanted a red collar, but didn't really like the fitment of the aftermarket options. So I 3D scanned the OEM collar, drew up a model in CAD with some modifications to improve durability, printed it on my resin printer and painted it myself. The model is available here for those of you who want to print your own: https://www.printables.com/model/1771694-oem-shift-boot-collar-for-honda-civic-type-r-2023
I highly recommend using a resin printer because it's a small part with a lot of detail. It's possible to print it with FDM, but support placement and removal is a massive pain and it'll probably need a lot of sanding to get the layer lines out. Make sure that whatever material you use is engineering-grade with a high elongation at break (>25%, >35% ideal) to make sure the locking tabs don't crack or deform when you're snapping the collar onto the nut. I used Sirayatech Blu Nylon Black for my prints. For FDM, something like eSun PETG should work.
Scanning was done with a 3dmakerpro Seal Lite. I ended up doing a total of 7 scans, then using CloudCompare to align them and create a mesh which I cleaned up in MeshLab. Finally, I could import it into Solidworks and begin the long and painful process of turning it into a proper CAD model.
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar 1783186689869-3r
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar 1783186836075-dn
The CAD model was sliced in Lychee and printed on my Mars 3 Pro using Sirayatech Blu Nylon Black resin like I mentioned earlier. Supports were placed such that none touched any surface that would be visible when installed in the car. I included this pre-supported model in my Printables link at the top of this post. When printing, I did have to keep the chamber heated to 30C because Blu is a pretty viscous resin.
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar 1783187847657-o5
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3861
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3865
Supports were removed, then each print was wet sanded to clean up as many support pock marks as possible. I didn't bother with most of them because they wouldn't be visible or affect functionality when the collar is installed. After one more IPA bath they were put into the cure station for final cure. After that I sprayed them with primer and I was finally ready to paint. It actually took me about 3 weeks to dial in my paint stack and get the finish I wanted. I was going for a metallic candy red that would look like a plain deep red normally but turn into a bright shiny metallic red when light hits it.
This is what I ended up with. All paints were airbrushed with a 0.3 mm nozzle except the clear which I did with a 0.5 mm nozzle, and the primer which was a rattle can.
  1. Tamiya Fine Surface Primer (Grey)
  2. Tamiya X-11 (metallic base, 3 coats)
  3. Tamiya LP-52 (clear red, 6-7 coats until I got the color depth I wanted)
  4. Clear coat from the Honda OEM touch-up pen, thinned with Tamiya lacquer thinner & mixed with Mr. Retarder Mild (durability, UV protection & gloss, 3 coats)
The 2 prints in the above image were test parts to see how my paint stack looked on the actual part. The ones shown below were the real parts. I made 3 in case I screwed up painting one/broke it/needed spares later.
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3904
Painting is finished!
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3974
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3971
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3972
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3973
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3869
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3872
I'm very happy with the result. I think it blends really well with the red accented stitching on the boot and carbon fiber surround. In total this project probably took me about 2 months. Most of that time was spent rebuilding the OEM part in CAD and experimenting with paints to get something I liked; though the multi-day cure times between layers didn't help. Anyway I hope some of you guys find the model useful.
honman
Rochester
2024 FL5 Type R
Awesome job! printed on a regular printer, great result.
Thanks! Good to know it worked for you. I only printed it with FDM twice when I was testing the initial model before moving to resin because I wanted a better solution for supports. If only I had a printer with independent dual extruders so I could use dissolvable supports. I MUCH prefer FDM to resin unless I don't really have a choice...
DmK
2025 FL5, Mx5 ND3
Agree I wish I'd have something like H2D to be able to print with dedicated support material at the same time.
I ended up using my X1C on the High Quality settings and was able to hide most of the support on the bottom, where it normally would be covered by the boot!
I have a stainless steel boot collar from acuity, so this was just a test print to see how good it would look, although who knows, maybe I'll get board and ended up printing full shift knob which would work with your print :cool:
honman
Rochester
2024 FL5 Type R
Nice, you probably have a more streamlined setup than I do haha. My main printer is a SV06 Plus that I HEAVILY modified with pretty much every part I could print better custom replacement parts for swapped out, plus better cooling fan/shroud so I can print PLA stupidly fast and tungsten nozzle for nylon carbon fiber filaments.
I'd be curious to know if you ever design a full knob. I'd love to make my own too but would prefer a metal part and don't have access to a machine shop or laser sintering printer (no matter how much I want one).
DmK
2025 FL5, Mx5 ND3
Yeah my machine is quite easy to operate I have multiple AMS machines so its basically swaps on its own with different Filaments. I got it 3.5 years ago and it was hustle free experience and very useful tool for me.
Nicely done with modifying your machine! I never went further then TPU with my printer.
honman
Rochester
2024 FL5 Type R
Yeah I've been wanting to install an AMS for a while. The SV06 and SV06 Plus are good printers and super affordable but do need a lot of modding for reliability and expanding the types of filament you can print. I have way too many types but mainly use PLA for quick prototypes and PolyMax PC (very high strength polycarbonate) for working parts. PolyLite PC is brittle but extremely rigid and temperature resistant which is why I used that to print brackets and stuff for the printer. I actually used PolyMax PC to make adapters for the OEM wheel center caps so I could put them on my winter wheels, and they survived 2 upstate NY winters so far. Polycarbonate in general is a pain to print though (PolyLite PC in particular likes to warp a lot, much worse than ABS) and is one that needs almost 300C at the hotend. Polypropylene is one I like to recommend if you have a build chamber. It's very flexible without fatiguing and extremely durable, but is also a pain to print. Since it's chemically stable I used it to make screw-on plugs and caps for my oxyacetylene cylinders/regulators/etc.
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3982
11th Gen Honda Civic I made a 3D printable model of the OEM FL5 shift boot collar IMG_3983
Superhatch
Jacob
Wisconsin
That black on red is a banger combo.
