I regret putting on 18's.
TheFactor
Factor
So Cal
2025 CW Civic Type R
I prefer 19’s for My application anyway just spirited street /twisties and only a few possible track days.
Love the looks but with that being said if I tracked it often I would definitely probably have a set 18’s for the occasion.
11th Gen Honda Civic I regret putting on 18's. IMG_2263
11th Gen Honda Civic I regret putting on 18's. IMG_2266
Sporky McGeuschky
Sporky
Central Texas
Sporky McGeuschky
Sporky
Central Texas
Which wheels are those?
Superhatch has the Enkei TSV in storm gray (18x8.5 +38) with a performance winter tire (Michelin Alpin 5, 235/40).
... or were you asking about mine?
My wheels are the MITA Motorsports FKS in size 18X9.0, ET +45, Center Bore 64.1mm.
The tires are Pirelli P Zero in size 275/45ZR18.
My suspension and camber are OEM stock.
Once again I must state my DISCLAIMER:
I mounted these tires for science... and here I have reached the limit of tire diameter in the FL5 wheel well. I DO NOT recommend a 45 sidewall on the FL5.
The tires WILL RUB.
I am definitely going to be sizing down to a 40 sidewall from here on out.
Cheers.
SKINNIE
DFW TX
ISF, 23' BB FL5
The tires WILL RUB.
Cheers.
Please do. Thanks 😂
arcticdc5
William
8.5 +38 is the problem. Tire and wheel is way too sunken in giving the car a daily driver vibe. 18x10 +40 or an 18x9.5 +38 would have been a much better choice for you.
MC BumSlap
J
North Bay, CA
'24 CW CTR
Wait, so 18x.95 +38 should be fine? I'm looking at a set of wheels now that I can get a very good deal on. Only thing is, I would need to get hub centric rings from 73.1 to 64.1. I've never had to buy rings...so...should I have any concerns?
rondre3000
San Diego, CA
No. The only concern would be whether they clear the brake caliper, which should be pretty easy to find out.
Shingo Shoji
Jeremy
FL5 - Championship White
They did an amazing job with the stock wheels I must admit. I just prefer the JDM look with more tyre.
CivR
Chris
Washington
I hated the stock tires. I replaced them with Conti extreme contact 2's 265/35/19 and everything improved for me; YMMV.
I needed a winter set for a area that can get a rare big snowfall but typically we get a few inches and its plowed away pretty quickly. eg; last season my driveway required plowing 3 times.
With these considerations I went Enkei TS-7 18x9.5+45 with DWS06+ 265/40/18. They don't look GREAT but they look fine and they perform. Sure I haven't seen snow and don't expect to for a while but the ride is fantastic and the performance is just fine.
Behold my phat tire phenom LOL
I like my tires like I like my women. Nice and meaty.
Sporky McGeuschky
Sporky
Central Texas
@Superhatch has your position changed on this now that you've had the wheels longer? Still gathering more facts but I'm beginning to develop a different theory on the 19 vs. 18 argument.:hmm:
FL5HondaGuy
Boston
2024 Championship White FL5
Stockers with a slight H&R drop taller 35 tire and some H&R spacers. Chefs kiss. Less is more.
11th Gen Honda Civic I regret putting on 18's. FL5Stanc
r
