J's Racing Hyper Intercooler
Brittania
Brian
North Carolina
2024 FL5
Been waiting for this! I've always been a "Buy once, cry once" kind of guy and I'm definitely leaning towards this one. Hope install goes smooth and it works great for you.
Install should be a piece of cake and I hope to get it done this weekend. I settled on the J's Racing intercooler after reading the forum and researching elsewhere. I prefer T&F vice B&P. Here is what I have been tracking for FL5 intercoolers in order of weight (low to high):
***EDIT*** Please reference this thread for up to date FL5 intercooler options.
  • OEM:
    • Type: T&F
    • Fins: 11
    • Tubes: 10
    • End Tanks: Resin
    • Stock IC Elbows: Retained
    • Core Size: 639 x 158 x 64 (25.16"W x 6.22"H x 2.52"D)
    • Volume: 393.6 cubic inches (6.45L)
    • Surface Area: 100,962 mm squared (156.50" squared)
    • Modifications: None
    • Weight: 6.9 lbs.
  • PWR:
    • Type: Hybrid B&P
    • Fins: 13
    • Tubes: 12
    • End Tanks: Machined billet aluminum
    • Core Size: ??? x ??? x 87
    • Volume = ???
    • Surface Area: ???
    • Weight: ~11 lbs.
  • J's Racing:
    • Type: T&F
    • Fins: 11
    • Tubes: 10
    • End Tanks: Sheet metal
    • Core Size: 700 x 172 x 100 (27.56"W x 6.77"H x 3.94"D)
    • Volume: 735.36 cubic inches (12.05L)
    • Surface Area: 120,400 mm squared (186.58" squared)
    • Modifications: Minor trim to move air temp sensor higher on the bracket
    • Weight: 13 lbs.
  • HKS:
    • Type: T&F
    • Fins: 10
    • Tubes: 9
    • End Tanks: Cast aluminum
    • Core Size: 695 x 178 x 100 (27.36"W x 7.01"H x 3.94"D)
    • Volume: 755.88 cubic inches (12.39L)
    • Surface Area: 123,710 mm squared (191.79" squared)
    • Weight: 15.65 lbs.
  • RV6 (yet to be released):
    • Type: Square extrusion T&F
    • Fins: 15
    • Tubes: 14
    • Stock IC Elbows: ???
    • Core Size: 695.3 x 177.8 x 101.6 (27.37"W x 7.00"H x 4.00"D)
    • Volume: 766.88 cubic inches (12.56L)
    • Surface Area: 123,624 mm squared (191.59" squared)
    • Modifications: ???
    • Weight: 16.4 lbs.
  • Wagner:
    • Type: T&F
    • Fins: 25
    • Tubes: 24
    • Stock IC Elbows: Replaced with silicone elbows
    • Core Size: 580 x 400 x 70 (22.83"W x 15.75"H x 2.76"D)
    • Volume: 991.86 cubic inches (16.25L)
    • Surface Area: 232,000 mm squared (359.57" squared)
    • Weight: 21 lbs.
  • PRL:
    • Type: B&P
    • Fins: 9
    • Tubes: 8
    • End Tanks: Machined billet aluminum (uses factory elbows)
    • Core Size: 720 x 184 x 109 (28.35"W x 7.24"H x 4.29"D)
    • Volume: 880 cubic inches (14.42L)
    • Surface Area: 132,480 mm squared (205.25" squared)
    • Modifications: Minor trim to move air temp sensor higher on the stock bracket
    • Weight: 22.6 lbs.
  • Airtec:
    • Type: B&P
    • Fins: 11
    • Tubes: 10
    • End Tanks: Cast aluminum (uses silicone elbows)
    • Core Size: 700 x 190 x 130 (27.56"W x 7.48"H x 5.12"D)
    • Volume: 1,055.10 cubic inches (17.29L)
    • Surface Area: 133,000 mm squared (206.15" squared)
    • Weight: 23 lbs.
  • MDR:
    • Type: B&P
    • Fins: 9
    • Tubes: 8
    • Core Size: 711.2 x 178.31 x 139.7 (28.00"W x 7.02"H x 5.50"D)
    • Volume: 1,081.09 cubic inches (17.72L)
    • Surface Area: 126,814 mm squared (195.56" squared)
    • Modifications: Removal of air temp sensor bracket and relocation of the sensor to a bracket on the top side of the intercooler
    • Weight: 29.5 lbs.
  • Spoon (yet to be released but likely inflated price for the label): ???
I narrowed my selection down to PWR, J's Racing and HKS that are all on the higher price end. I decided on J's Racing because it is T&F and IMHO has an optimal core design where details are provided rather than just marketing buzz words. Intercooler pressure drop and efficiency are other considerations but that information unfortunately is hard to locate.
The intercooler includes new O-rings where the tabs need to be removed prior to installing per the instructions. Most instructions when dealing with O-rings do not detail what else should be done with them before installing to prevent binding, twisting, or drying out and sticking over time. Easy fix is to use dielectric grease on them. Never use Vasoline on rubber as it absorbs causing expansion and distortion post installation. Here is a PIC of the new O-rings with tabs removed:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743817153273-aa
Dielectric grease added to them and ready to go:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743817205449-xq
NoviceFL5owner
Keith Green
stl
Install should be a piece of cake and I hope to get it done this weekend. I settled on the J's Racing intercooler after reading the forum and researching elsewhere. I prefer T&F vice B&P. Here is what I was tracking for intercoolers:
  • OEM: B&P, 7 lbs.
  • PWR: B&P (US) and T&F (Australia), ~11 lbs.
  • J's Racing: T&F, 13 lbs.
  • HKS: T&F, 15.65 lbs.
  • RV6: T&F, ~16.5 lbs. (yet to be released)
  • Wagner: B&P, 21 lbs.
  • Airtec: B&P, 23 lbs.
  • PRL: B&P, ~25 lbs.
  • MDR: B&P, 29.5 lbs.
  • Spoon: ??? (yet to be released but likely inflated price for the label)
Wagner is T&F. Pretty sure stock is too.
Be curious if the HKS ic pipes would fit this. Regardless, nice ic!
Thanks and yes, the HKS intercooler piping kit includes replacement cast aluminum in and out pipe elbow connections where the intercooler connects. As such, the kit should work with any intercooler that mates to the stock in and out pipe elbow connections.
I like how the HKS intercooler piping kit also replaces the stock rubber intercooler hoses with mandrel bent aluminum tubing. I only wish that it also included tubing to replace the stock cast aluminum throttle body inlet pipe (a.k.a., upper charge pipe).
HPS is another alternative intercooler piping kit to consider. It does not include replacement cast aluminum in and out pipe connections like the HKS but does provide an additional tube to replace the stock cast aluminum throttle body inlet pipe. HPS is also lighter on the wallet. I want to order that kit but could not find a vendor that had them in stock (apparently they are on backorder until the June/July timeframe).
Zpeedster M
New York
2023 Type R FL5
Ordered mine from HPS during Holidays
11th Gen Honda Civic J's Racing Hyper Intercooler IMG20250326173212
Edited post #3...Stock intercooler weighs 3,131 grams or 6.9 lbs.:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743902820753-bt
From the outside, it looks like a B&P. Inside it looks like T&F so T&F it is I guess:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743902968102-l2
Backside views of the HKS intercooler on the left and J's Racing intercooler on the right. Note the differences in the end tanks around the Frankenstein rubber bushing connection points.
11th Gen Honda Civic J's Racing Hyper Intercooler 1743906145540-65
So the stupidly simple one page installation for the J's Racing intercooler was 100% accurate. As described, the only trimming necessary is to modify and move the air temperature sensor higher up on the existing stock tab. Here is a PIC of where ribs were cut off of the stock tab and a hole drilled higher for relocating the connection point itself:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743912562619-2r
Bottom section removed:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743912655142-jt
PIC of the sensor after intercooler installation:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743913784642-pd
PIC with the front bumper on:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743914840951-vu
Remove the plastic side duct plates from the rear of the bumper:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743953697912-o4
Transfer the two rubber bushings from the bottom of the stock intercooler to the J's Racing intercooler and install the new O-rings from Post #4. At that point, position the intercooler ensuring that the two bottom rubber bushings are fully seated. Then reinstall the two stock top brackets that include rubber bushings. At that point, there are only six bolts to tighten to compete installation (the two top bracket bolts and four bolts to connect the end tanks). Torque specifications for the two top bracket bolts are 9.4 N⋅m and the other four bolts are 22 N⋅m (sourced from the HKS intercooler installation instructions).
Left side:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743957614272-ps
Right side:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743957648624-42
Install complete:
11th Gen Honda Civic J's Racing Hyper Intercooler 1743957686364-uk
Before reinstalling the front bumper, it is also a perfect time to replace the stock horns. I upgraded to the dual Euro Horns (Honda Part # 08P80-T60-000). Install PICs and notes were shared in this post.
Thanks for the writeup! Are you seeing any significant difference in IAT's?
