Need Help with Invidia Q300
BC504
New Orleans, LA
2024 CW CTR
I have a Q300 sitting in my garage waiting to be installed on Friday, I can follow up with pictures after complete. Just have to fight my tips a bit since the slip-ons are out of round on all 3 🥳
Classic Invidia packaging
I can tell you just from playing with the system after unboxing that there should be a lot of room to adjust the tips to your liking, the only one that is not adjustable in or out is the center since it also bolts to the muffler section for support as its carrying the valve and a resonator. The outer tips can be slid in or out as far as you want to create the look you're after. I plan to set mine dead even with each other and the diffuser.
Rudy25FL5
Rudy
Central Florida
Well can’t wait to hear your feedback. I’m glad that there is some adjustability. Thanks again!
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
For what I saw, the INVIDIA 400 is the one sold here. I also saw that one, but you put it on the search engine, and it doesn’t seem to pop up for FL5. For what I gather.
You're partially right. We convinced Invidia USA to start offering them here. Initially they only offered the R400, thinking that all Type R owners would want the louder exhaust.
https://unity-performance.com/search?q=invidia+fl5
BC504
New Orleans, LA
2024 CW CTR
Got the install knocked out and it was surprisingly easy to bend the piping with vise grips to get the tips on so no real issue there.
You can’t completely set all 3 tips flush with each other but you can get them very close. The center solidly mounts and the outer tips when flush with the center aren’t slipped far enough onto the piping for me to be comfortable with, but it still looks great IMO.
11th Gen Honda Civic Need Help with Invidia Q300 IMG_8908
11th Gen Honda Civic Need Help with Invidia Q300 IMG_8912
11th Gen Honda Civic Need Help with Invidia Q300 IMG_8915
Rudy25FL5
Rudy
Central Florida
That looks really good ! How do you like it so far and do you have any more pictures from the back? Thanks again
Evox787
Elvin
looks really good and not as far out! How loud it is? The outlets are the same size the 3 of them?
BC504
New Orleans, LA
2024 CW CTR
Looks great from the rear. The adjustable rear hangers let me tuck it up pretty high which I prefer.
11th Gen Honda Civic Need Help with Invidia Q300 IMG_8910
I had a remark dual tip stainless exhaust before so it’s the easiest way for me to compare it. Valve open it’s louder than the remark, valve closed it’s quieter with a hell of a lot less drone. I would call it oem+ with the valve closed and completely tolerable under load even for someone like me who gets headaches easily and often.
all 3 outlets are the same size as well.
Seika
Seattle
2026 FL5 Type R - CW
Could you put different tips on to the Invidia Q300 if you wanted to?
BC504
New Orleans, LA
2024 CW CTR
The outer tips could easily be swapped for something else but the center tip is riveted/welded on (can’t remember which). Where there’s a will there’s a way though
