PRL Motorsports 1.5T FMIC Kit Development
Status
Not open for further replies.
Akalawur77
PA
2017 Civic Si Coupe
Yes, though this is there for duct work to help promote optimal air flow.
More updates! Our prototype is complete! We will be testing next week! All piping will come standard powdercoated textured black.
11th Gen Honda Civic PRL Motorsports 1.5T FMIC Kit Development DSCN0746_zpsfz3fvvig
11th Gen Honda Civic PRL Motorsports 1.5T FMIC Kit Development DSCN0747_zpse6eota1y
11th Gen Honda Civic PRL Motorsports 1.5T FMIC Kit Development DSCN0749_zpsdyqmdyfg
Looks very promising, I love getting full kits with the charge piping! Any ideas for pricing or group buys?
PRL Motorsports
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
FMIC Friday? Finally we have some dyno testing and data for you guys!
11th Gen Honda Civic PRL Motorsports 1.5T FMIC Kit Development Civic%20X%20PRL%20IC%20Cat%20DP%20FP%20S1_zpstjxj5gn
Here is an overall comparison from what we have gathered thus far with our 2017 Civic Si in terms of gains. We chose the dyno runs to compare because these are all 4th gear pulls with identical coolant temps and knock values (~55%). All of these pulls are untuned and using the factory Honda ECU mapping.
  • 100% Stock Civic Si Baseline: 186 hp & 215 ft/lbs tq
  • 100% Stock Civic Si + Stage 1 Intake: 191 hp & 216 ft/lbs tq
  • 100% Stock Civic Si + Stage 1 Intake + Catted DP/FP Combo: 207 hp & 221 ft/lbs tq
  • 100% Stock Civic Si + Stage 1 Intake + Catted DP/FP Combo + FMIC Kit: 216 hp & 224 ft/lbs tq
In other words we gained 9 hp and 3 ft/lbs tq by simply bolting on our FMIC kit in comparison to the factory intercooler setup.
Before anyone says it, we already know somebody is going to say, "OMG that's it?" Let's take a bigger look at this.
11th Gen Honda Civic PRL Motorsports 1.5T FMIC Kit Development Civic%20X%20Stock%20IC%20PRL%20Cat%20DP%20FP%20Heatsoak_zpsxjesqmlc
Here are three back-to-back (all runs within 2 minutes of each other) 4th gear dyno pulls with the stock intercooler, our Stage 1 Intake and catted downpipe/front pipe combo. As stated in an earlier thread, this car HATES 4th Gear dyno pulls from the factory. Notice the power loss from heatsoak during these back-to-back dyno pulls. This heatsoak only gets worse on hotter days or during even more extreme conditions like extended spirited driving and racing.
Run 6:
  • Knock Value 55%
  • Coolant Temp: 178 F Start / 189 F End
  • IAT Pre IC: 99 F Start / 100 F End
  • IAT Post IC: 99 F Start / 124 F End
Run 7:
  • Knock Value 55%
  • Coolant Temp: 190 F Start / 212 F End
  • IAT Pre IC: 102 F Start / 102 F End
  • IAT Post IC: 115 F Start / 138 F End
Run 8:
  • Knock Value 55%
  • Coolant Temp: 200 F Start / 228 F End
  • IAT Pre IC: 107 F Start / 108 F End
  • IAT Post IC: 126 F Start / 156 F End
11th Gen Honda Civic PRL Motorsports 1.5T FMIC Kit Development Civic%20X%20PRL%20IC_zpstlk82td
Here are three back-to-back (all runs within 2 minutes of each other) 4th gear pulls of the same car, but with our FMIC kit added. The car responded MUCH better to repeated abuse and testing; heatsoak was drastically reduced.
Run 6:
  • Knock Value 55%
  • Coolant Temp: 181 F Start / 201 F End
  • IAT Pre IC: 96 F Start / 96 F End
  • IAT Post IC: 90 F Start / 99 F End
Run 7:
  • Knock Value 55%
  • Coolant Temp: 196 F Start / 217 F End
  • IAT Pre IC: 100 F Start / 102 F End
  • IAT Post IC: 95 F Start / 104 F End
Run 8:
  • Knock Value 55%
  • Coolant Temp: 199 F Start / 218 F End
  • IAT Pre IC: 105 F Start / 99 F End
  • IAT Post IC: 96 F Start / 106 F End
All dyno testing was performed on the same day. We saw as much as a 50 degree drop or an average of 36 degrees in post intercooler intake air temps on stock ECU mapping by simply swapping out intercooler setups. These results will only be amplified when running more boost via ECU tuning. More boost out of a tiny turbocharger = higher temps. Higher temps = increased chances of knock/detonation, thus limiting power and reliability.
Though the power gains may seem minimal on a stock or near stock car running factory boost levels, gains become much greater when turning the boost up and pushing things to the max. Aftermarket intercoolers are intended to reduce post intercooler intake air temps as much as possible to make the engine and forced induction system as efficient as possible, thus drastically improving engine/component longevity. We expect our Cobra CAI system to compliment this FMIC quite well in an effort to reduce intake air temps even more! :thumbsup:
bmbpenguin
Brian
Brian
Indianapolis, IN
2017 Civic Hatchback Sport, 2007 Odyssey, 2003 Accord EX-V6
So your results show stock intercooler is actually raising the temperature of the intake air? Also, are you willing to share the PID codes for the IAT pre and post IC? i'd like to program that into my Torque app and see what mine is running. thanks.
Run 6:
  • Knock Value 55%
Run 7:
  • Knock Value 55%
Run 8:
  • Knock Value 55%
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Run 6:
  • Knock Value 55%
Run 7:
  • Knock Value 55%
Run 8:
  • Knock Value 55%
Charge air temp, yes, this is very common with stock or inefficient intercoolers. If cooling efficiency is lacking, the core will begin to heatsoak during repeated abuse like back-to-back pulls. Off the top of my head I don't know PID codes for the torque app. We used our Hondata FlashPro to datalog.
Shankmeyster
AZ
23 Type R
I don't know why anyone would be whining about HP gain here. This is more about reducing intake temps than anything else right?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
We have a big announcement to make for the 10th Gen Civic 1.5T community... Pre-orders for our FMIC kit (compatible with both Si and Non-Si models) are finally available!
Kits will retail at $799.99, but we will be selling these at 20% intro pricing for only $639.99 until pre-orders begin shipping. Though we aniticipate orders to begin shipping a bit sooner, we set an ETA at 90 days from today to compensate for any bumps in the road with production along the way.
http://prlmotorsports.com/2016hondacivic15tfmickit.aspx#.WZyAlT6GOUk
Kit Includes:
  • Front Mount Intercooler Assembly
  • (4) 4-Ply Silicone Coupers
  • (8) 304 Stainless Steel Worm Clamps
  • (1) Hot Side Intercooler Pipe (Textured Black)
  • (1) Cold Side Intercooler Pipe w/ Mounting Bracket and Machined Billet Aluminum Flange (Textured Black)
  • (1) -4AN O-Ring to 1/4" Hose Barb (Black)
JDM_DOHC_SiR
Uncle Dave
Chula Vista
Awesome!!!!
placed into my basket on your site... Just waiting on the Cobra Race CAI to get finished up as well so I can order at the same time :bow::headbang:Thanks @PRL Motorsports
Status
