gtman
Mitch
2017 Cosmic Blue EX-L Sedan
The key takeaway from D-Rob is "when evaluating dyno results, the important number is the difference between the factory calibration baseline testing and the final results."
I mean honestly, that's the only comparison that really matters and the only apples to apples result. Same car, same dyno, same day, stock vs. tuned.
OsosikMedia
Nick
Sik! Can't wait to see the parts you develop for the 11th Gen Si.
Hondata
Hondata
Torrance California
www.hondata.com
Didn’t @Hondata claimed 222hp lol
To be accurate, Hondata measured 222 hp. To be even more informative Hondata measured this as a 10% power gain over the 10th gen using an identical ramp rate of 500 rpm per second to minimize the effects of rotational inertia.
Jes_si562
Jesse
Long Beach
2018 civic si. 1990 Honda civic w d16z6 swap (sold)
@D-RobIMW any guess on honda changing lower internals and fuel system to something more juicy
HondaFan777
2023 Civic Type R, 2023 Pilot Elite
"Accurate" isn't a word that should be used when talking about dynamometers.
Every. Dyno. Reads. Different.
You cannot compare numbers from two different cars on two different machines.
So is the Si Turbo different or is it the same as the non Si 1.5T?
Curious what is different on the engine.
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
'06 RSX-S, '18 NSX, '21 TLX-S, '22 RDX ASpec
procivic
Ventura, California
www.procivic.com
2022 Civic Si Sedan, Others
Right off the bat, we can see that the 11th Gen is making considerably more peak horsepower (a maximum difference of 19WHP and 20WTQ). This is due to Honda’s utilization of a twin scroll turbo (this term can be used loosely, we'll discuss this at a later date), dual port head, and the current generation having VTEC on the intake and exhaust side, which allows the head to flow much better at high rpm. This is also demonstrated by the horsepower and torque bump at peak boost, around 4200 RPM, whereas the 10th Gen torque curve begins to dramatically fall off as RPM increases.
That's very interesting. Great post. Do you know if for sure the intake side does indeed have the traditional variable lift VTEC mechanism, or is it just VTC?
I know the L15CA has variable lift VTEC on the exhaust side as well as VTC, but on the non-Si I'm under the impression the variable lift VTEC is more for fuel economy (as in the valves can go into a low lift mode maybe when cruising or in other scenarios). It would be nice if Honda added some extra lift capability on the exhaust side of the Si motor.
