JDM_DOHC_SiR
Uncle Dave
Chula Vista
2021 TLX Type-S / 2023 Civic Type-R / 2024 HRV EXL
Things are moving along much quicker than initially expected. We hope to have some news for you folks this spring!
Does this include…. Let’s say an ahead of schedule development for a certain inter cooler and piping :hmm: :wave:
UFO CTR
San Frrancisco, CA
FK8 #1348 (Sold), FL5 #682
Does this also mean the FK8 exhaust and downpipe will work with this front pipe on the FL5? I think some forum member already confirm FK8 downpipe will work and that the exhaust will probably fit. anyways, just wondering out loud :hmm:
PRL Motorsports
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
2017 Civic Si, 2016 Civic EX-T, 2018 Type R
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development 329968692_734102931449256_735530334194845306_n
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development 323786852_757659612381626_2541430125238104246_n
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development 334250348_147500721211680_4058567693490523339_n
Just look at that billet goodness! :drool: FL5 Intercooler Upgrades and charge pipes will be available VERY soon. :thumbsup:
HONDANB
JOHN DOE
FL
NEEDED
Are those actual FL5 intercoolers??? They look way smaller that the black 3D printed version on the short video you made. 🤔
elusiveaura
Tennessee
2023 Civic Type R - SGP
@PRL Motorsports Dustin williams posted a video regarding your intercooler. They mentioned modifying and cutting inner part of the grill and ducting of sort. Is this required? They also mentioned drilling a hole to relocate the air temperature sensor. I thought it was going to be modification free. And when is this releasing since he has it already?
saGOD
Andrew
Illinois
2023 Honda Civic Type R | 2020 KIA Sedona
Dustin's video mentioned the intercooler will be available to the public 4/7.
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Yep, same size! It's probably just an illusion because the factory intercooler isn't next to it for comparison.
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development 71170-T20-A00.PNG
He is referring to the plastic "front bumper safety plate" (Figure #7, part number 71170-T20-A00) that goes over top of the factory bumper beam.
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development 338292847_218541197496876_7702777925025618169_n
The tab where the ambient air temperature sensor is attached needs to be cut for proper clearance, and a new hole will need to be drilled into the front bumper safety plate to relocate the ambient air temperature sensor.
Yep, this is the plan!
elusiveaura
Tennessee
Do we have a price or a preorder initial price or Intercooler only option or will Intercooler come with charge pipes automatically?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
A new video is up on our YouTube!
As well as the data from our intercooler testing!
https://prlmotorsports.com/blogs/news/2023-honda-civic-type-r-fl5-intercooler-upgrade-testing-data
Now that our prototype billet end tanks are complete and sample cores are in, we have decided put together a few functioning intercoolers to test that our design lived up to its expectations. Our engineers datalogged some street driving with our 2023 Honda Civic Type-R FL5 using both the factory and PRL Motorsports intercooler upgrade before heading to the dyno. The dyno session was started by taking a completely stock baseline run at an average temperature of 59°F and an elevation of 1160ft. Here’s what we found:
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development HCR11 PRL vs Stock IC Cold.PNG
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development Pressure Differential.PNG
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development Inlet vs Outlet Pressure.PNG
Once strapped to the dyno, we started out by doing a few power pulls, to establish a baseline for before and after installing our intercooler. All pulls were were done starting at 180 degrees coolant temp. With the factory setup, we saw a peak of 302WHP / 323WTQ, and with the PRL intercooler, the car was able to make 310WHP / 327WTQ. During both of these runs, we logged the pressure differential between the inlet and the outlet of each intercooler. The factory intercooler had an average of 0.6psi of pressure drop, compared to the PRL which had an average of 0.4psi. Both the dyno graph and the log of the pressure behavior show that there is virtually no loss in turbocharger spool in comparison to the factory intercooler.
Following the power pulls, we wanted to test how well the intercooler actually dissipates heat. In order to do this, we did back to back pulls with the car on the dyno, with equal time intervals (30 seconds) between each pull. This was repeated this until we saw the outlet temperature of each intercooler reach a heat-soaked equilibrium, where it no longer increased significantly.
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development Inlet vs Outlet Temp.PNG
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development Ambient Temp.PNG
For the PRL intercooler, we were able to perform 15 back-to-back fourth gear dyno pulls until we reached heat-soak, which was a maximum of 170°F at the intercooler outlet. The maximum intercooler inlet temperature we experienced was 323°F, and the average ambient temperature entering the intercooler for these runs was 82°F.
For the factory intercooler, it was only able to achieve 9 back-to-back runs before reaching heat-soak, which we saw the outlet temperature reach a maximum of 196°F. The maximum inlet temperature reached was 330°F, and the average ambient air entering the intercooler was 73°F.
As a recap, our testing showed that the PRL intercooler reached an equilibrium heat-soak temperature that was about 26°F cooler than the factory intercooler, and took 66% longer to reach heat soak. Overall, our intercooler performed significantly better than factory. Unfortunately, at the time of this test, we were unable to log any OBD2 data on the car, but according to the LogR dash readout on the car, during both runs, we stopped once the coolant and oil temperature were between 230°F and 235°F. It is worth noting that the car was able to achieve 12 consecutive power pulls with our intercooler upgrade before plateauing around 235 degree coolant temps. With the factory intercooler, it was only able to achieve 8 consecutive power pulls before reaching 240 degree coolant temps.
11th Gen Honda Civic PRL Motorsports 2023+ Civic Type-R FL5 Product Development HCR11 PRL vs Stock IC Heat Soaked.PNG
Once each car achieved full heat-soak, we did another power check the current power output. With our intercooler at full heat soak, we saw a maximum figure of 270WHP / 301WTQ. With the factory intercooler at full heat-soak, we saw a maximum of 237WHP / 258WTQ. When looking at the graph of inlet and outlet pressure during the heat soak test, you can see that the ECU is pulling boost with the factory intercooler as a safety. By the final run, we were down from 25psi to about 16psi.
Something else worth mentioning is that the sensors we used to log near the intercooler were reading a peak boost level of around 26-27psi, whereas the MAP sensor in the intake manifold was seeing 22-23psi, suggesting the factory charge pipes may be a restriction in the intake tract. We're working on a fix for that as we speak.
Intercoolers are in production and are expected to available within the next few weeks. Stay tuned!
PRODUCT LISTING
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Charge pipes are currently in production, just awaiting for our castings. We're still probably about 90 days out from release.
