R513CTR build thread πŸ‡¦πŸ‡Ί
r513ctr
Sydney, Australia
Honda Civic FL5 Type R
Hey all,
Picked up my RR CTR a few months back now and have just started the build, car currently has 6xxxKM. The goal is to build a track ready daily driven car.
So far the the following has been done:
- Tein Mono Racing Coilovers
-Eibach adjustable rear upper control arms
- Hardrace front camber ball joints.
- CE28N Plus 18x10 +40 in OG bronze (BR)
- RE71RS 275/35R18
-GDevolpment titanium bolts through out the car, I'll be leaving some of the bolts factory but anything that isn't critical will be swapped.
Alignment and corner balancing has been done by Terrence at Trustalign (tezzasaurusrex on the forums).
I'll update the thread as I go, few things I'll be looking to be doing in the near future are some cooling mods, exhaust/downpipe & CAI plus a fluid flush and brake pad upgrade.
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί FB_IMG_1751297547146
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί FB_IMG_1751297550482
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί FB_IMG_1751297542442
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί FB_IMG_1751284439160
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί FB_IMG_1751284444784
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί FB_IMG_1751284465723
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 20250403_165639
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 20250403_165628
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 20250625_131106
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 20250627_193716
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 20250627_193731
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 20250629_172611
SInce you plan to track it, have you looked into rigid collars? Not many people consider them but they definitely help maintain your alignment under load.
r513ctr
r513ctr
Sydney, Australia
Yeh it's something I'll eventually get to, probably should have done it when the suspension stuff was getting done but wasn't high on the priority list. I know alot of 90s Honda guys sware by them.
I have them on my car and the difference could be felt before I got on the street
neptune
how does the car feel after corner balancing? like the poster above me said, rigid collars would make the turning feel direct and solid. i have coils, rear motor mount, and rigid collars and this car feels so fast in the canyons. i feel super confident going into turns. next on my list are rear camber arms and corner balancing.
r513ctr
r513ctr
Sydney, Australia
After the alignment/corner balancing the car feels amazing, have gone for a few hill runs and have had nothing but confidence in the car once the tyres are warm. I do need to adjust the rebound on the Tiens as it is a little too stiff ATM (currently 8 clicks from the hardest setting).
In regards to the rigid collars I have added them to the list but as of now I have other things I'm prioritising.
r513ctr
r513ctr
Sydney, Australia
Sorry for the lack of posts work has been flat out.
Car now has a Remark titanium exhaust system with Dream Automotive catless down pipe, Hondata has also been installed running a base map for the time being. I've also ordered a Voltex GT type 2 wing (12 month ETA πŸ˜”) as well as an Eventuri turbo pipe and CAI which should be here soon.
Engine and gear box fluids have been swapped to Motol, brake fluid has also been swapped to Endless. Front brake pads have been changed to Dixcel type Z though I'm not really a fan of them so may swap them out at a later date, Alplus titanium shims were installed with the pads.
See below for some sound clips.
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000010475
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 9e1db3da-5146-4b5f-a875-26bf8f365b4c-1_all_792
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000004974
r513ctr
r513ctr
Sydney, Australia
Today we installed an Eventuri CAI and Turbo tube, the quality and fitment is perfect. Performance wise power felt good though the revrange, checked trims and all was good though I'll be looking to get the car tuned once I've installed an intercooler.
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000015437
rwong324
Richard
nj
honda civic type r fl5
What type of trims were you seeing? Under 10% ltft?
r513ctr
r513ctr
Sydney, Australia
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000024897
Meet up with a few old friends I haven't seen in awhile last night and went for a hill run, car handled well.
Recently rotated the tyres as I had some wear on the fronts partially due to them being a little flat, hoping the currently set last till the new RE71RZ are released here.
r513ctr
r513ctr
Sydney, Australia
Couple new additions to the to the car, set of RE71RZ and a Voltex type 2 GT wing with custom carbon risers in 225mm provided by Terrence at Trustalign.
Varis bonnet should be here by the end of the year then I'll install the Exceed lip and get the front end repainted, car has quite a few stone on the front end from weekend back road drives.
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000052388
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000052396
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί Messenger_creation_4C45504E-AE19-45FF-840D-6F500F5E2272
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000048407
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000048409
11th Gen Honda Civic R513CTR build thread πŸ‡¦πŸ‡Ί 1000052103
