Rear camber arms needed after lowering FL5?
HONDANB
JOHN DOE
FL
NEEDED
Have you had to use camber arms for the rear???
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
If you want absolute perfection to dial it in you will need rear camber arms. That being said if you just did a small drop on some springs you are good to skip those for now until you get a more aggressive drop or want to start dialing in specs for road racing.
nodnarb901
Brandon
Olive Branch, MS
Glad I saw this thinking about lowering spring and was wondering if these were needed. Thanks.
TypeOne
Baton Rouge
Type-Rs!
It depends on how low you are planning to drop the car and if you care about setting the camber back to (as close as you can get it with) factory specs.
My car is lowered on swift springs and I have not used a rear camber kit.
sam3r_11
GTA, CANADA
Type R
Hi there, I plan on lowering with springs about 1 " drop
this might be a no brainer question to some but I'd like to understand this well rather than blindly do what every one else is doing... considering both rv6 camber arms and spc adjust camber but from two different positions on the knuckle (upper and lower) is there any concern if one were to install both at the same time even if it was only to help reduce weight since they are lighter than oem
i don't fully understand why camber can be adjusted from two different positions on the knuckle (spc upper, rv6 lower)
again if one were to get both does that mean they can potentially run -6 °, 3 from spc and 3 from rv6 .... not that i would do that but just trying to understand what or how the oem was designed and what those two vendors were thinking when making two different replacement improved products for the same end goal
azev
Oregon
CW FL5 CTR
I am also curious about this... initially I just need rear camber adjustment, but eventually I'd like to swap all the rear suspension component with rubber bushing with the solid bushing counterpart.
Which one should I get first, SPC or RV6 camber arm ?
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
Not needed, but I did it for the sake of it, running SPC arms.
-Josh
JATypeR24
Josh
Vero Beach
2024 FL5
Same I didn't need it but i went with SPC and got the car re aligned. I dropped it 1" with the eibach kit car looks great even with factory wheels. Waiting on my spacers to come in to see how that'll make it look.
juguuu
Arizona
CBP 24 Type R
You can't really adjust the front unless you have coilovers. There are ball joints available but they don't really adjust but give a "setting" for 1 degree in the negative or 1 position in positive camber. All depends how low you go.
ctechauto
You can, its just very limited. The top hat strut holes are elongated/oval and you can move the strut in/out about .5 degrees (-ish) if you pull the top strut pins on the stock top hats.
Now add camber plates + LBJs and you can get like -6+ degrees of camber with the elongated holes too :cool:
