Rear camera guide lines not aligned properly?
dragonate
Nate
Hey all! I just picked up a 24 fl5 a few months ago and I was wondering if anyone else was having the same issue with their reverse camera. the guide lines seem offset to the passenger side so it makes it seem i'm parked too far over to the right even though I am within the lines. Is this just how honda reverse cameras are or is this something I should have the dealer take a look at? My last honda was an 02 s2000 so didn't have to worry about cameras back then haha. Thanks!
11th Gen Honda Civic Rear camera guide lines not aligned properly? unnamed
11th Gen Honda Civic Rear camera guide lines not aligned properly? unnamed (1)
11th Gen Honda Civic Rear camera guide lines not aligned properly? unnamed (2)
dragonate
dragonate
Nate
I believe the dotted line is supposed to be where your bumper actually is comparable to the grid.
oh gotcha, i didnt know that! thats good info. I was actually talking about the vertical guide lines though and how in the camera it makes it look like the car is parked on/outside the lines when i'm actually inside. I pulled out of the parking spot a bit just to get a better view of the lines in the camera.
Oh, well that makes more sense on why you're out so far, helps if I actually read it again lol. Its possible that it may be off, the dealer should be able to recalibrate it if needed.
dragonate
dragonate
Nate
I'll take it in to get it checked out, thanks!
dragonate
dragonate
Nate
I assume it's because the rear camera is off to the side slightly?
I was thinking that initially too but i realized that if the camera placement was causing the offset the lines would be offset to the left but currently its offset to the right ?.
arbies
Scott
Austin, TX
2023 BB Type-R
Ah, you're right. In your picture, the camera is closer to the side with the single white line, but the rear view shows that the angle is over towards the double white lines. This is strange.
BasicFL5
NorCal
Civic EX
Yup.
Just got mine about a month ago and it does this too. I have to open the door to make sure I'm not to far on one side or the other. Mine also seems like it's closer than it actually is.
Websitesdown
Yup.
Makes backing out of my walled driveway a blast. ?
TheFactor
Factor
So Cal
2025 CW Civic Type R
I’ll have to check mine to . I know on Friday nights I just close one eye and it lines up perfectly ?
