Recipes to make 400 hp
how much WHP can RV6 R660 get with tuned 91 octane?
It will make more than 400whp but octane will limit the capability. I agree with @Two Step Performance in evaluating your goals and go with the most responsive turbo that achieves that.
In my opinion this will be the most enjoyable setup. Going too big makes good power but the lack of response makes it less exciting and defeats the purpose of the car.
BuntaTypeR
This is an easy one and lots of fun!
The 27WON Kuro will make ~420whp on 93 octane and ~470whp on an E30 blend
https://www.twostepperformance.com/...upgrade-kuro-for-2017-2021-honda-civic-type-r
Required supporting mods:
https://www.twostepperformance.com/...mer-tuner-for-2017-honda-civic-type-r-fk8-fl5
https://www.twostepperformance.com/...honda-civic-type-r-fk8-fl5-integra-type-s-de5
https://www.twostepperformance.com/products/e-tune-for-ktuner-or-hondata-email-tuning-service
Recommended supporting mods:
https://www.twostepperformance.com/...-upgrade-for-2017-2021-honda-civic-type-r-fk8
https://www.twostepperformance.com/...onda-civic-type-r-fl5-integra-type-s-de5-2-0t
https://www.twostepperformance.com/products/billet-intercooler-upgrade-for-the-2023-fl5-civic-type-r
** Fueling upgrades would be required to use an E30 blend. It's a big step up in cost - https://www.twostepperformance.com/products/fuel-system-upgrade-for-2017-honda-civic-type-r-fk8
The 471 WHP pull shown above utilizes the quick spooling 27WON Kuro. The 529 WHP pull uses the slower spooling but higher top end producing RV6 R660. Both torque and WHP can be limited as desired during the custom tuning process.
bear with me here.
do you need flex kit for this or I just buy/install this and get tune?
i have e85 across the street so this is very doable.
bear with me here.
Good question. To this point there is no flex fuel kit available that works with Hondata. They are releasing their own kit "soon". That is the ideal solution whenever they make it finally available. Until then you are forced to monitor your ethanol percentage another way, which can be done, but is more work. The flex fuel kit makes it easy and takes a lot of the guess work out of it.
For someone considering an E30 build, I would tell them to wait on Hondata to release their flex fuel kit to make that part easy.
FL5ghost
Charles
Tampa
2023 civic type r
I like the way you think. I'd really like to see some other turbo options come out before I upgrade. However want something that spools quick and still pulls.
I had hks 3037s on my evo and it was perfect.
MHI stage 2
Higgs Boson
Texas Hill Country
A little off topic, can anyone comment on Hondata capabilites vs HPTuners? I've been using HPT on a few hundred cars over the last 15 or so years. Can I do all the same things to my Civic with Hondata regarding recalibration or is it more basic? Do I have access to fully calibrate all the necessary tables myself or will I have to use a tuning company with a different version of Hondata than I buy? What kind of access is there to OBDII codes, etc?
Apples to orange I'd say. Hondata is more simplified. Tuning companies and end users have the same Hondata software access. Hondata typically has more custom features than what you'd see from HPT. Of course what HPT offers varies widely depending on the application. And as I am sure you already know, they do not offer anything for this application.
Higgs Boson
Texas Hill Country
For sure, just want to make sure if I get Hondata I won't be limited to what I can do for tuning the car for mods that require it.
FL5ghost
Charles
Tampa
2023 civic type r
The Kuro is another good option, more responsive and almost same HP. Bit more headroom on the MHI so depends on what you are using it for.
Isn’t the Kuro smaller?
keonigt
Keoni
Hawaii
2024 Honda Civic Type R
Would the flex fuel kit be required if I'm just planning on running regular fuel (92 octane) and no E85 at all?
So i'm able to run the turbo setup with just FBO and this would be reliable?
Yes you can run the car on normal pump gas. And it will be reliable. You don’t need a flex fuel kit if you are not using ethanol.
You won’t be limited and it is very user friendly.
Hondata has the most features available of any tuning option for this platform at this time. We are still waiting on MOTEC support but the cost of that will not make sense for most. (estimated $8000 or more)
We have found the Kuro to be sized just right for the K20C1 owner that wants to maintain a quick spool but still have a lot of fun with their car. It has been our #1 selling turbo for the FL5/DE5 platform. The Kuro is not new to the market but it was a bit of a hidden gem until people started realizing that there is definitely such thing as too large of a turbo in some cases. I do think the MHI Stage 2 is another solid option but the cost can be hard to justify when compared to the Kuro, both having excellent reliability records.
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
+1 for Kuro, it's been a hidden gem for too long, especially with the FK8 guys but really caught on with FL5 and DE5.
We have Kuro 001 on our FK8 still going strong after 3 seasons and 25k miles, making 426/393 on 93, and 470/421 on E35
Last year we put the Kuro on the FL5 as well. It's the easiest 400+ recipe, with the power coming in nearly as quick as stock without losing a top-end
