Regamasters - Tarmac vs Normal?
Bonito
Atlanta
Finally looking to pull the trigger on a set of Regamasters for the FL5 and I ran into a very small hiccup. What is the difference between the tarmac and normal versions? It looks like it is just the lip (or lack of, see below). Without the lip, I would imagine that the tarmac are more of a curb rash hazard. Do any of you have experience with these?
My current setup are Gram Lights 57DR in 18x9.5 +38. It looks like the Regamasters only come in 18x9.5 +38 in the tarmac version. Otherwise the closest offset I can get on the normal version is +45. Are there any more sizes I should be looking at that will maintain the aggressive stance of the +38 but won't risk rubbing?
As always, thanks!
11th Gen Honda Civic Regamasters - Tarmac vs Normal? 1739608055980-o0
11th Gen Honda Civic Regamasters - Tarmac vs Normal? 1739608094805-x2
princers
Z
25 Type R
diff lip face as you saw and tarmacs are available in diff offsets / are slightly heavier (.25 lb per wheel iirc)
TypeRVA
Neal
Richmond, VA
2024 Honda Civic Type R
I think they Spoon versions have some additional offset choices geared towards the FL5
Tougefl5
As always, thanks!
Tarmac actually protect the rims a little better with tire. That’s the only difference between the two. As for the weight my 18X9.5 5X120 17.99lb
11th Gen Honda Civic Regamasters - Tarmac vs Normal? 20241222_085646
Bonito
Bonito
Atlanta
You have the same setup I’m looking at, black satin on CW. So those are the +38 tarmacs? And do you have more photos? The dish depth looks great on those.
TypeRVA
Neal
Richmond, VA
So no rubbing at all with the +38? I've been worried to do anything but +45. Figment looked killer though.
Tougefl5
I'm on coilovers and camber balljoints no rubbing. Can't vouche for stock set up though.
Bonito
Bonito
Atlanta
I’m on stock with +38 57DRs with absolutely no rubbing, not even close. That said, I haven’t dropped it all so I’m not sure if throwing Swifts or Eibachs on there would change that.
TypeRVA
Neal
Richmond, VA
I have some Spoon Springs that I am going to install when I get wheels. Will probably go +45 just to be safe. Thinking the Gram Light 57NR.
svvitch
I highly doubt they would rub even lowered. There are some running 18x11 on Swift on track no rubbing.
dandaman15
Milwaukee, Wi
2014 RDX, 2023 Type R
It may depend on your tire size and if you have the strut pins pulled for extra camber.
Im running 18x9.5 +38 on swift with 265/35 and its really flush in the front but no rubbing. Running a 275 may cause some slight rub.
11th Gen Honda Civic Regamasters - Tarmac vs Normal? 1739655328576-m8
Back should have no issues
TypeRVA
Neal
Richmond, VA
What wheels are those? Can't tell from the angle but they look good.
NeRO_CTR
Joeeezy
Commiefornia
The EVO II has a bit of a replica feel, while the Tarmac II stays true to the original aesthetic of the larger wheels (back when 16" or the Promada line were the only options that offered such a lip). FFWD 20 years, the real looks like the fake. In my case, due to rim size, there is no option, it shares the EVO II replica wheel lip. A catch 22, even if I win, I lose. ?
