Remark Triple Tip Exhaust
Answering my own question here (and posting it for anyone else who's curious), Remark updated the specs for this exhaust with the weight:
That's a little disappointing, I was hoping this would weigh less than the OEM exhaust. I hear mention of a future titanium version, perhaps I'll wait for that.
FYI - It's not uncommon for the stainless steel aftermarket exhausts for this platform to weigh more than the OEM exhaust. Most, if not all, of the stainless steel exhausts for this platform way more than the OEM exhaust. If you truly value weight savings, you have to go Ti.
naafl5
Maryland
Disappointing for sure but I wouldn't lose sleep over .2 pounds. Maybe skip lunch on the days it's driven /s.
Looks like those interesting looking resonators might be the culprit.
FL5Guy
South Dakota
2023 CW FL5
I've noticed that, I had my hopes up because this system uses a small straight-through muffler for the loud pipe and only resonators on the quiet side. I figured this may result in weight savings but I was wrong!
It's not a deal-breaker for me, I was just hoping to kill 2 birds with 1 stone by also saving a bit of weight. I would like to keep the car relatively stock while also reducing weight where possible, as long as it doesn't sacrifice drivability or utility.
naafl5
Maryland
Might end up going with a dual resonator delete and buying the Milltek valve controller. Get rid of some weight, get some growl/depth, and no hondata tune needed to keep the valve open. All under 600-ish USD.
I got a thread on it on this forum trying to gather some more sound clips.
Nothing
2023 CW FL5 #5044
Isn't the valve controller itself $400?
MSUGeoman
Josh
Tennessee
2023 Civic Type R #2486
Did 27Won downpipe and fuse pull trick to keep the valve open on the stock exhaust, I’m content with it honestly, it’s worn in now and sounds good without being obnoxious.
akacs
MK
SF Bay Area
This exhaust comes with a “front overpipe”. What is that?
My understanding is that it’s still a catback, and it won’t affect smog/emissions in anyway… and will be treated as a catback (non-engine mod) from a honda warranty perspective? TIA
The front pipe connects to the downpipe which has a catalyst. It's technically still considered a "catback" system. As for the Honda warranty, no one here will be able to definitively speak to that because it depends. My advice, which may not be popular, is to not modify the car if you value the warranty.
The front pipe connects to the downpipe which has a catalyst. It's technically still considered a "catback" system. As for the Honda warranty, no one here will be able to definitely speak to that because it depends. My advice, which may not be popular, is to not modify the car if you value the warranty.
This should be like a sticky on every car forum on the internet.
It depends on the dealer and the problem you come to dealer with but if you fuck around, you might find out. Its dumb that it is that way but thats the way of the world.
egxflash
CA
2024 Integra Type-S
"BUT MAGNUSSON MOSS!!!!" /s
100% agree with you. Or at the least, put on things that are easy enough to swap the OEM parts back in if you have issues.
watchmegrub
Calvin
'24 FL5
Without a tune, does anyone know what the power gains are on this exhaust? I thought I saw it somewhere before but now I can't find it.
