gamaarayz
Aaron
2022 civic si
I have been riding on these coilovers for well over a month now and I feel I can give a pretty good review on them. Coming from a 10th gen hatch, The coilover install was pretty easy, as are most coilover installs I assume. Only glaring issue I noticed on my 22si when installing was how finnicky the cv axle joint is.. don't wanna pop it out.
The Price point - It's justified (see below)
The Build quality - Incredible, they look and feel amazing right out of the box.
The driving feel - I went with the super low option, Default spring rate is 8k/8k The ride is incredibly comfortable even at a *somewhat* stiff springrate. the only time I ever noticed slight discomfort was really bumpy roads. Since then I have swapped to 12k/8k swifts for a bit of a stiffer front end (fitment reasons) and it still rides incredibly smooth.
The customer service - Amazing, William helped me so much in figuring out what I needed.
The cons - Tapered lower mount... Now.. I know this isn't really up to Silvers, this is more a, Honda not making the strut diameter wide enough type of deal... that's fine, Just know, if you plan on going low boy, you'll either need to custom order even shorter shocks or just dump the car on some 3" 326 springs. (this is really the only con that I can think of)
If you have any questions, lmk and I can probably answer them. As of now I cant thing of anything else off the top of my head.
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si A7400279-min
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 324550876_498951275683419_816569005146131853_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 324695052_1390398798366585_4230810526877308259_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 323900553_6317185754976237_2963475496247550817_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 323871296_674047964506770_9135254916525283733_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 324079504_653717083167936_4749039355838423461_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 319480547_673062314368531_2657303228975487794_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 318992285_119230247513228_2429273102583114554_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 319809472_196175796308097_650337272024630874_n
11th Gen Honda Civic Silvers Neomax Coilovers (review) on 2022 Civic Si 319572307_680303730285592_8755638931785828296_n
mikeyc712
2022 Honda Civic Si
Thanks for posting information about the coilovers. I do have one question, where did you get that splitter and who makes them?
Tac3403
Tyler
Missouri
16 civic ex-t
Made an account just to say this thing rocks. That is exactly the type of fitment I'm after on my 10g. Normally not big on rpf1's on modern cars but wow that really works. Interested in wheel and tire specs for future reference.. This has made me want to go out and buy a new si instead of dumping money into my 16 LMAO.
alhounos
Oregon
I have a feeling you're going to get more questions about that sick fitment than the coilovers, lol. :cool:
So you might as well post the details now... What's the drop? alignment specs? wheel specs?
OGGsr
Jamie
Richmond VA
PWP 2022 Civic Si
My guess: 18x9.5 +45 with 255/40s
EDIT: zooming in on one of the pictures looks like 265/35?
Looks GREAT!
DoubleRFe1
Netherealm
2023 Honda Civic SI
SI looking fantastic and love the wheel setup. What's the specs on the wheels and tires?
apexit53
Madison WI
2023 CTR, 2023 Integra aspec MT
Looks GREAT!
my money is on +38 for the offset
gamaarayz
Aaron
2022 civic si
Any idea on how to make a proper reply? is what i'm doing right now the right way? I dont use the forums too often so I dont know
OGGsr
Jamie
Richmond VA
PWP 2022 Civic Si
I think what people are wondering is the wheel/tire combo you are running and an estimation of how much you lowered your car on your coilovers.
apexit53
Madison WI
what youre doing is good! this way when you respond to this persons comment they get notified and can get the answer!
Car looks good btw... thining about doing the same on my integra!
chopsuey34
West Michigan
2025 Civic Si
We would like to know your set up:
What is the size of your tires?
What is the size of your wheels & wheel offset?
How much did your car's ride height drop when you installed your coilovers?
What are your current camber / toe / caster specs?
gamaarayz
Aaron
2022 civic si
tire specs: 265/35 all around
wheel specs: 18x9.5 +18 front (20mm spacer) +35 rear (3mm spacer)
how much of a drop? not sure, I eyeballed, its about a quarter inch from being maxed out
alignment: -3.7 front, -4 rear, factory alignment the rest
chopsuey34
West Michigan
2025 Civic Si
Great, your car looks amazing, by the way.
