Spying on you?
Sporky McGeuschky
Sporky
Central Texas
To hell with all this Big Brother crap. I’m building a Flux Capacitor, and I’m out. Wait till they see the FL5 in 1960!
"Where we're going... the government doesn't blow chodes."
tc0566
Jim
Canton, Ohio
2025 Honda Civic Type R
Did you try using a FAT32 formatted USB drive to then follow the steps to update via USB on the car? If so, a JSON file should have been copied to the drive where you then remove the USB drive, insert it into a computer and upload the JSON file via usb.honda.com.
If there is an update available, download the ZIP file and save it in the "HondaSoftwareUpdates" folder. Return to the car, reinstall the USB drive and follow the prompts on the screen to complete the update. After completion, a report is saved as a JSON file and the software is updated on the car. Return to your computer, install the USB drive and upload the JSON report to usb.honda.com.
I am not sure what step failed when you attempted, but give the above a try. I just updated mine via USB without having to reconnect the TCU.
Everytime I try USB, the file copied to the drive says corrupt by the website. I've tried multiple drives, all 16GB drives formatted Fat32.
11th Gen Honda Civic Spying on you? Screenshot 2026-04-10 170637
0x1d7
Washington
2025 Civic Type-R
I pulled the TCU from my 2025 Type-R, super easy with some plastic spudgers. Also decided to remove the TCU on my 2025 Hybrid CR-V; start from the passenger side towards the window rather than the portions that surround the infotainment section. TCU is the same part # for both cars. I found the CR-V cables gummy; wear gloves.
Now I can finally remove the layers of tinfoil.
11th Gen Honda Civic Spying on you? image1
11th Gen Honda Civic Spying on you? image2
marcusm86
Marcus
Missouri
2025 Civic Type-R
I can only guess its because it doesnt need an update.. ive tried mine as well with the same error.
tc0566
Jim
Canton, Ohio
Problem is it can't check to see if it needs an update because the identifying info is in that corrupt file.
zumbooruk
Ventura CA
I started getting a new Connection error
The error is newish (I first saw it about four to five weeks ago)
when it does not need upgrade, there is a different message
zumbooruk
Ventura CA
I've used the same file to check for updates for about a year now (file dated 6/5/25)
until a few weeks ago, it gave message that there was no update
recently, I keep getting a connection error
11th Gen Honda Civic Spying on you? 2026-05-20 at 10.06 AM
tc0566
Jim
Canton, Ohio
Problem is without that file the website can't check to see if you have an update. That file contains the model number and the software version on your in dash stereo. I can't get the stereo to copy a good file to the USB drive.
zumbooruk
Ventura CA
That's a different issue than what I am seeing. sorry, got confused.
I got the file from the car onto a USB drive
I was able to check for update until a few weeks ago
A few weeks ago I started getting the "Connection Failure" error above.
Which means that I cannot connect to the Honda server to even check/verify my file.
marcusm86
Marcus
Missouri
2025 Civic Type-R
So i used a different drive and the corrupt file did not have my VIN after the deviceID. But i am getting the connection error with the proper one.. This was failing on a 256GB drive partitioned to only a 30GB Fat32 partition - the rest was empty (no volume made). A 16gb flash drive with no partitions only formatted to FAT32 looks to get the right data.
{"deviceData":{"deviceID": "VIN GOES HERE"
This was with the non-corrupt file
11th Gen Honda Civic Spying on you? 1779307585497-f9
tc0566
Jim
Canton, Ohio
I've had multiple different drives 16gb fat32 come up as corrupt. Today was my first time getting in and didn't see corrupt files. But I have no idea if my previous files were actually corrupt. I never checked them to see what was in the file until today.
marcusm86
Marcus
Missouri
2025 Civic Type-R
I hooked mine up to a hotspot and it was up to date.. donno if that gives you peace of mind or not
zumbooruk
Ventura CA
Thanks.
TCU removed, and I have not be able to check for an update the last few time
I am not losing sleep over it.
The update is only for the infotainment system related stuff such as:
Android OS
navigation (which I permanently disabled)
LogR which I rarely use
audio which I never listen to
etc.
Apple Carplay kept disconnecting.
I set it up for USB only, since I always connect my phone to the USB (older phone, battery nearly gone, needs to always be charged)
if/when there is an update that might resolve the Carplay connectivity, and if/when I get a new phone, I might update.
Mawfuqqa
FL5 #9000!!
Upon discussion with some m8s someone brought upon that eventually they (they meaning all spyware new cars any make/model) will be notified tcu or similar spyware is disconnected and insurance can/will go up. What anyone make of this. Mine has been out the car for months now insurance price seems the same.
side note - phone is not connecting wifi/bluetooth now as well. I tried erasing/forgetting and reconnecting. No dice. Back to using a cable, I usually use for dash cam but good thing there are 2 ports.
Starting with MY27 all cars will have government mandated spyware type systems, in the guise of preventing drunk driving. Unfortunately it allows government access to a lot of data they might not otherwise have and don't necessarily need.
And yes insurance companies want to know if the MY27+ system is disconnected, if for no other reason than to raise rates. I'm not sure they'll have access, but they'll try.
