Steering feels harder to turn to one side
Posted this in the recall thread but maybe better to make own thread.
I am not sure if this was due to the recall because I don't remember feeling it but maybe I was just not paying attention.
The steering is slightly harder to the left than the right, its almost like to the right feels like its in comfort and left is sport. Its not much harder but enough for me to feel it.
My wheel is also not centered and I honestly don't remember when this happened, I could have sworn was not like this before getting the recall done (took an hour so definitely the new method and not removal of subframe). I have rotated the tires, tire pressures are good and the car has had an aligment, actually had 2 but the wheels still not centered even after I told em about it.
Anyone experience this or have any sugestions?
This is due to the recall. Please take it to a dealer as soon as possible.
I actually scheduled an appointment this morning.
So did you have this too? what was the solution?
a c i d.f l y
Austin
2024 Honda Civic Type R
They need to regrease the worm gear and replace the spring. Essentially, what happens is that the spring pressure is so high that it pushes grease out, resulting in you eventually being unable to turn in one direction. This affects the direction you turn more often, which, for me, is left-hand turns, given that I live near a major highway.
The fix takes less than 30 minutes.
What is happening to me is after the recall was performed.
If you prioritize right hand turns like UPS, then you'll never ever have the issue. Just gotta work smarter, not harder!
11th Gen Honda Civic Steering feels harder to turn to one side 1ki3yl
Hello @MooMoo did you end up figuring out the issue? I am experiencing the same symptoms and would Iove to know your solution. Thanks
Have never figured it out. I kind of forgot about it, its not a lot so I guess I just dealt with it and drive the car. Obviously I wish it was not doing it but it does but still works fine.
However I honestly think it was the recall that did this, can't prove it and maybe it has always been like this but I noticed it after the recall because I was looking for changes.
If you figure it out please do let me know
