Forged AL6061-T6 and 7075 T6 billet aluminum are the BONOSS options. The materials are comparable. Aeroflowdynamics has had a spotty record though so, YMMV. Anyhow, I'm a fan of choices. Thanks for sharing.
FL5HondaGuy
Boston
2024 Championship White FL5
Check out Bros FOURR Speed on YT , Just put 20MM FR /25MM RR on his 24 FL5 with H&R springs.
whos_CTR
Thomas
CA
Is there a reason why some people are running staggered spacer sizes? ie: 15mm front 20mm rear. Aren't the OEM wheels squared? Also for the long term, will these "bolt on" style spacers seize up after a long period of time? Or no because they use studs and nuts? I ask because I ran 5mm slip on spacers on my previous car and they eventually got stuck. Ended up just leaving them on the car when I got traded it in.
arcticdc5
William
Yes, the front wheels protrudes out slightly more to the edge of the fender as it compares to the rear. Off the top of my head it was 1/4" or even 3/8". Getting a staggered spacer fitment gives the car an "even poke amount" look.
msos
2025 Civic Type R (replacing BMW M2 Competition), BMW X3M and McLaren Artura
Just installed H&R 22mm spacers all around and very pleased with the result. All stock 2025 Type R, no other wheel tire/suspension mods! No rubbing! Thank you all for your input made this all so much simpler! Also did install myself in about 90 minutes!
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_7973
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_7972
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_7975
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_7974
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread IMG_7971
B16B
2025 Honda Civic Type R
FL5 looks great with spacers. Has anyone noticed any changes with the handling after installing spacers?
jdezee
Jack
sanford, FL
1. Year and model:
2. Wheels/offset:
Front: Stock-19x9.5 OEM Matte-Black Alloy, ET +60
Rear: Stock-19x9.5 OEM Matte-Black Alloy, ET +60
3. Tire size:
Front: Stock- Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL
Rear: Stock- Michelin Pilot Sport 4 S 265/30ZR-19 93Y XL
4. Suspension:
Stock Suspension, Type ADS unit
5. Wheel Spacer Brand and Size:
Front: Bonoss +20mm
Rear: Bonoss +20mm
6. Clearance (i.e., Does it rub? If so, when?)
Front: No rub
Rear: No rub
7. Wheel Studs
Front: Stock, no alteration needed
Rear: Stock, no alteration needed
8. Insert photos
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread PXL_20250314_202120330
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread PXL_20250314_204112966
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread PXL_20250314_204107944
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread PXL_20250314_204122692
vote4anh
Anh
DC2R
Greetings! Question for all running Bonoss, Are you encountering any vibrations?
jdezee
Jack
sanford, FL
Bonoss 20mm on all 4 corners, not a single issue. In fact it feels better with the wider track width. I would take it apart as something may not be seated correctly.
vote4anh
Anh
DC2R
Thanks for your experience!
I have not done it yet, but from my experience of other spacers, it has happened. But it can be attributed to many reasons (Improper install, not torquing right, and etc.)
No vibrations, no issues. FWIW, while not many miles, they've been on the car for over 2 years.
jdezee
Jack
sanford, FL
Got it, I was assuming you were already having an issue. Overall they were really nice spacers. I've used some higher end spacers before on other vehicles and these are just a nice quality. I would definitely recommend them.
Pics below for reference
11th Gen Honda Civic The FL5 Civic Type R Wheel Spacer Reference Thread PXL_20250314_202124804
Sazabi
Subaru BRZ
Does the 20MM make the wheel stick out a little bit? I'm sure in person its hardly noticeable. Contemplating between 15 vs 20 all square.
Evasive
PSL Florida
2025 BB FL5
What a great thread.. Thank you to all for the pictures and information. I did notice many times people wrote no rubbing with springs and the 20-25mm spacers on back. Does this include people in the back seat? Just wondering if 2 people, potentially 300+ pounds total would cause rubbing issues with the springs and spacers...Didn't see it specifically mentioned....Thanks!
