Transmission worries.
Lukeklaas
Luke
Fk8
Hi I have a fk8 and after mild grinding 2nd gear ( even with taking 1-2 slow and yes, with my clutch pedal all the way down) at about 40,000 miles my transition exploded and the case broke and everything. It was pretty traumatizing and definitely took my lovr away from that car. It was also heavily modified and pushing over 400 whp which might have to do with it but I didn’t even break it on a hard pull. Either way I’m looking to get a new car and the second gear grind is scaring the hell out of me and I want a stock reliable car. Please tel me if the transmission should stop me from buying this car. I love everything else about it but if that transmission starts grinding again I might have a heart attack lol
For the FL5 second does not like to be hurried but no transmission grinds as of yet.
RacingIsLife
Wisconsin
OP how often did you change the transmission fluid?
From my experience doing track days, change the transmission fluid, change it often. And the trans will be happy.
I have like 12 quarts of the OEM honda trans fluid and will be changing pretty regularly.
Lukeklaas
Luke
Fk8
I changed the transmission oil to ac delcro after I started noticing the grinds, so I changed it couple times during the 40,000 miles.
RacingIsLife
Wisconsin
likely already on the way out when u changed the fluid then. thats just ho the cookie crumbles at times my man
HONDANB
JOHN DOE
FL
NEEDED
FL5 trans is "improved" according to Honda but it's still a FWD trans. Be gentle. They don't like the 1-2 and 3-4 power shifts. No matter what anyone says
ABPDE5
New England
2024 Integra Type-S
I've never seen or heard of 3-4 issues on K20C. Agreed re: 1-2 you should definitely be gentle.
Honestly, I am not sure why you wouldn't be gentle 1-2 w. this car... if you want to launch, don't buy a FWD, lol.
I've noticed that many people will increase performance, and not increase their maintenance at the same time. The higher the power output, the more preventative maintenance will be needed on a more frequent interval. Not saying that your situation could have been avoided, but it seems like it would make more sense to get a replacement transmission for your fk8.
HONDANB
JOHN DOE
FL
NEEDED
Just because you haven't heard it doesn't mean it doesn't happen.
I have, from drag racers. Track is easier on the trans than drag.
ABPDE5
New England
2024 Integra Type-S
Right!
...which is exactly why I said: "I have never seen [or heard of] of 3-4 issues on K20C."
I didn't say: "There's never been a K20C transmission w. a 3-4 issue."
Jokes aside: I do know 4th gear is relatively weak, and HRC offers a hardened option even for track applications.
To OP: This transmission, in its stock application when used as Honda intended, is pretty much worry-free. There are 1-2 grind reports, but not on the scale we saw w. FK8. And, these are often accompanied by reports of aggressive 1-2 shifting. This is not an 8th-gen-esque transmission.
That said, if you start adding lots of power or using the car in ways it was not engineered to be used in its stock form (i.e. drag racing, clutch dumps), expect you may run into issues and need to upgrade weak points.
Right!
Even with conservative added power there should be no issues. Most of this stuff is people being very aggressive on the car or you are pushing north of 600whp lol.
Noize
Under the radar
All of this can be alleviated by showing some mechanical empathy when shifting. There’s no reason you shouldn’t be able to make 450 or even 500hp with the stock gearbox.
