Sound Deadening Project
Monkey_Luck
Jeremy
Apex NC
2022 Honda Civic SI
I have started installing everything and this takes a lot more time than I thought it would. So far i have installed NVX CLD. Closed cell foam and 1" double scrimmed thinsulate in the entire hatch area. I am currently working on the rear doors have installed NVX CLD and 1" megazorbe pro in both rear doors. The rear door panels i have applied CLD and lots of thinsulate. I am still working on the inner door skins and will be making block off plates out of 1/32 lead sheets wrapped in CCW.
11th Gen Honda Civic Sound Deadening Project 20260718_153013
11th Gen Honda Civic Sound Deadening Project 20260719_111056
11th Gen Honda Civic Sound Deadening Project 20260719_155815
11th Gen Honda Civic Sound Deadening Project 20260808_112831
11th Gen Honda Civic Sound Deadening Project 20260808_164340
11th Gen Honda Civic Sound Deadening Project 20260810_131700
11th Gen Honda Civic Sound Deadening Project 20260810_131826
johnloov
John
Make sure you use one large piece in doors or pieces are connecting. Sound likes to go around.
johnloov
John
Another big upgrade I did recently is I’m racing in 275/35/19 on stock rims Pirelli pzero corsa’s and the ride and noise is much better. I did get a bit of wheel rub on one side because my front fender liner was sagging because I sound proofed the wheel arches then used some glue to hold it close. Zero metal contact and now zero rub on fender since I glued it closer to metal. It was simply sagging due to the weight of the foam I installed on wheel liner. I’m now able to go to the track and home in super comfort, and even less noise than before. The only downside is gearing is slight increases so it’s off by 2-3 mph and I can feel it on long straight aways at Cota, but then again I have zero wheel hop anymore flooring it first and second, and actually compared to the stock cup 2 and stock 4s lap times I am 2-3 seconds faster at Cota. The best I could do at COTA on oem dt1 4s was ~2.42 cup 2 2.41 and oversized 275/35 stock rims Pirelli pzero corsa streetable track tire was 2.39
11th Gen Honda Civic Sound Deadening Project IMG_2983
11th Gen Honda Civic Sound Deadening Project IMG_3065
11th Gen Honda Civic Sound Deadening Project IMG_3865
11th Gen Honda Civic Sound Deadening Project IMG_3785
Han_Solo
Johan
Johannesburg, South Africa
2025 Honda Civic Type R FL5
Are you running the standard damper module or the ITS module?
I have the same tyre setup and it made a huge difference in terms of ride comfort and NVH. I will look into sound proofing the wheel-wells in future and then stick the plastic tighter to the body. Thanks for the tip.
Klazer
Minnesota
2024 Honda Civic Type R
I just did this same project over the weekend. Have only done the trunk area, rear wheel wells inside the cabin, and rear bench. Butyl rubber 80mill killmat nearly everywhere, roughly 90% coverage. Used the eggshell butyl foam layer on top of that, only for trunk and wheel wells. To finish I covered any remaining gaps and the seams of lower foam layers with the 4mm foam layer. Making about 75% coverage with the 4mm foam.
TLDR
Rear Bench seat
  • Killmat - 85% coverage
  • 4mm foam - 100%
Trunk / Wheel arches
  • Killmat - 90%
  • Butyl + Eggshell foam layer 90%
  • 4mm foam - 75%
Incredible results already, and I have not done the doors yet. Super excited to experience what that will be like.
My question to you John-
How did you manage fitment for the plastic cover that goes over the hatch latch?
Also, were you able to maintain fitment for your folding trunk floor to lay within the groves of the trunk?
If you look at my photos, the wheel arch panels are pushed towards the inside, so it is messing with fitment. I believe I used the exact materials you used, aside from the initial butyl layer. I have thought of cutting out some material where the floor level shifts for the trunk floor insert, to let everything rest closer to stock.
Thanks
https://www.amazon.com/dp/B0751CBXBT KILMAT 80 mil
https://www.amazon.com/dp/B0CCRF9MGW TroyStudio 3 in 1 Car Sound Deadener
https://www.amazon.com/dp/B0BWD1M9Y5 Sound Deadening Mat 157mil(4 mm)
I'm having the same issue here with adding the sound deadening materials. Seems like I can't get the plastic trunk floor to sit flush anymore because the arches have been pushed in.
Has anyone else dealt with this?
Monkey_Luck
Jeremy
Apex NC
2022 Honda Civic SI
This is a great video, especially explaining the concept of resonance using a cymbal as the major source.
Now I'm wondering where to get better door seals and acoustic glazing for the windows.
I just installed Lexus door seals like in this video a few hours ago. Will let you know the results.
johnloov
John
Send pics mine are perfectly flush. I did struggle initially but not much.
johnloov
John
I have all the photos here somewhere in this thread
Monkey_Luck
Jeremy
Apex NC
2022 Honda Civic SI
Please let me know if this makes a meaningful difference, then I'll do it. Looks great! Flush and clean looking, I like it.
It does make a difference but only after i started my sound deadening/sound absorbing journey.
The door seals do make a difference. The more sound deadening/absorbing i do, the more new noises i hear. If you would have ask before i did anything, not sure you would be able to tell a difference.
johnloov
John
I hope Honda is listening. They could easily engineer a well insulated sports car, with minimal weight penalties. They can for sure do it, with way less weight than I had to put in. Everyone is complaining even about the Integra Type S in the recent car and driver long term 40k review - road noise is terrible.
The road noise is ruining a near perfect car. Since I've done the noise insulation, and also put on the larger profile tires, the car now is near perfect, and still performs extremely well on track. There has been zero downside that's measurable. There has been a substantial upside in ride quality, and to me the Type R mode suspension dampening is greatly improved by planting the rear of the car.
I hope Honda makes the next generation Honda Civic Type R road noise free! - let's only hear engine and the good stuff. Honda stop the migraines and tin can effect.
