Club-Version x M|M|E Shim-Adjusted Rear Toe Arms
Club Version
Jose
www.youtube.com
FL5 Championship White
Hi all!
I’m excited to announce that I’m helping develop the first shim-adjustable rear toe arms for the FL5, FK8, and DE5 chassis. TCR race cars use shim-adjusted arms, and I’ve long wanted a similar solution for our street cars. After more than 30 track days in my FL5, testing each modification individually, I’ve reached the point where the factory arms and their rubber bushings were limiting rear-end response during high-lateral-load corners. In turns such as Bishops at Sebring, the car does not respond immediately because the bushing must first deflect and settle under load. This delay between the applied force and the car’s response is known as “phase lag.”
Recently, at a local track day, I met Sven from Meisterschaft Motorsport Engineering and explained what I was experiencing. We quickly began developing a solution. Sven’s experience working with leading motorsport teams confirmed that the shim-stack design is proven in competition, including TCR and GT3 Cup cars. After further discussion, I offered my car and driving feedback to support development and testing. The rear toe arms are only the beginning. Additional products now in development include shim-adjusted rear camber arms, spherical-bearing trailing arms, and, ultimately, a billet-aluminum rear lower arm.
To begin production and continue testing, we need at least 10 reservation orders. We will make the final production decision on Friday, October 16, 2026. If at least 10 reservations remain active on that date, we will move forward. Reservations withdrawn before the deadline will not count toward the minimum. If fewer than 10 reservations remain, we will either proceed with production or automatically refund every deposit, and we will notify all participants of the decision.
Please find the reservation link below with more detail information regarding material choices:
MEISTERSCHAFT MOTORSPORT ENGINEERING / RESERVATION
Most adjustable toe arms are threaded: turn the rod end, lock it with a jam nut. The setting is held by thread friction and the clamp of that nut, so it depends on correct torque and on counting turns to keep both sides equal. The rod ends also have to be clocked so each ball sits in the middle of its travel before the nuts go tight. Lock one at an angle and the bearing runs against its limit, binds, and wears out early.
This arm sets its length with a stack of shims clamped between the arm body and the bearing end. The length lives in solid metal and the bearings are pressed in at a fixed angle, so there is nothing to clock. Each shim is a fixed step, the same stack gives the same length on both sides, and a setting can be changed and put back exactly without an alignment rack.
Enjoy the following renders of the Toe Arms and please reach out if you have any questions!!
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms LSTV1968
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms JEUO0649
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms JJLF9561
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms NAZE9389
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms JBFF9918
nojeebs
25 FL5
Love the design! Reminds me of the ones I had on my gt3. I'm 50/50 right now on doing it since I'm really trying to keep the car borderline tolerable for family use still bwahaha. I'm going to let it simmer in my brain for a bit.
Club Version
Club Version
Jose
www.youtube.com
I completely get it! lol let it simmer…
Club Version
Club Version
Jose
www.youtube.com
I’m in. This is exactly what I was looking for
Thank you!
The rear camber arms will have the exact same shim adjustments as well. That’s the next part in the development pipeline.
Club Version
Club Version
Jose
www.youtube.com
Ok you mentioned shim adjustment camber arms so now I'm all in. 🙃😂
Thank you so much I saw your reservation came through!
We just need three more reservations to begin production and testing! 🙌 I gotta reach out the FK8 community.
tezzasaurusrex
Terence
Very cool idea. Reservation placed. Key is good quality spherical joints and replacements are available
Club Version
Club Version
Jose
www.youtube.com
Thank you so much!
We are going ahead with 3-D printed prototyping the arms, as we just need one more order.
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms Screenshot 2026-09-29 104235
In addition, M|M|E already offers the basic threaded toe arms. Those will be available for sale at $450 once the Shim-adjusted arms are ready. Just note, the primary focus is still on the development of the shim-adjusted arms.
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms threaded toe arm 2
11th Gen Honda Civic Club-Version x M|M|E Shim-Adjusted Rear Toe Arms threaded toe arm 1
Club Version
Club Version
Jose
www.youtube.com
Just a quick update everyone!
We have reached and surpassed the minimum order threshold! We're shooting to get the first arms installed and tested at Sebring on my car by December. 🙌
Will update with actual photos of the arms once they have been produced.
Again, thank you to everyone who reserved!! I'm very excited for this little project and hope all of you will enjoy the chassis improvement out on track.
