Beware 15400-RTA-003
Evox787
Elvin
I bought 3 filters online on one of these "Honda" part stores, because I refuse to go to my local dealer due to the fact that they are a crap dealer and shady. The other dealers are an 1hr or more. Anyway I pay 30 dollars for 3 filters but since I have the car, I’ve been using the "bad" one without any issues. Decided to see what was the fuss of using the Japanese one but got scammed I think because all the 003 I find pictures are different to the ones I received, I will attach pictures but I will be sticking to the 002 because has been working fine for me anyway. Probably I’m wrong but I’ll be throwing them away to avoid any headaches. Just beware that now they are making copies of your beloved Japanese filter and the stores aren’t even bothering on checking them.
11th Gen Honda Civic Beware 15400-RTA-003 IMG_6962
11th Gen Honda Civic Beware 15400-RTA-003 IMG_6963
11th Gen Honda Civic Beware 15400-RTA-003 IMG_6964
11th Gen Honda Civic Beware 15400-RTA-003 IMG_6965
Evox787
Evox787
Elvin
See if you can get yourself am actual 03 before you throw them out, the images online could be inaccurate. Would also save you some time and money.
Yeah, it is just that now the only option is online and I don’t think I will trust that venue again.
Xmetal
CTR, S3
Sorry, please educate me? What's the tell tell signs that these are counterfeits? Thanks.
SonicRSC
Russell
SC
2026 Honda Civic Type R Sonic Gray
That's why I but the Amsoil filters. They always work fine, and are way over OEM specs for micro filtration (20microns) and are made with high quality materials.
zymmer4
Howard
West Virginia
bought a pack of 3 off Amazon https://www.amazon.com/dp/B0CWG8JYDS a while back. 3 filters and 3 washers. Washers were not packaged with the filter; just rolling around the shipping box. seems legit but take a look, thx
I bought those and as I change my oil every 5000 miles, and use 5W30, I have had NO ISSUES..I have not opened one up to look at the construction details.
Spart
2025 Integra Type S
I'm not saying that's 100% fake, but the label looks wrong, is the wrong orientation on the box, and the shrink wrap on the filter doesn't look tight enough.
Here are some examples of what a label looks like on a Japanese market filter (from websites in Japan)
11th Gen Honda Civic Beware 15400-RTA-003 1791558177163-ic
11th Gen Honda Civic Beware 15400-RTA-003 1791558489622-bg
11th Gen Honda Civic Beware 15400-RTA-003 1791558509624-d5
11th Gen Honda Civic Beware 15400-RTA-003 1791558913675-zf
There are subtle variations in the label on these, but they're all real.
Here's an example of a fake that looks allllmost real:
11th Gen Honda Civic Beware 15400-RTA-003 1791559874096-p2
A few things stand out on this really-close-but-still-fake filter:
  • The corners of the label (more noticeably the red ones on the top, but also the white ones on the bottom) are rounded off, whereas the real labels are squared off.
  • It's hard to tell in the photos, but the red on the real Honda labels is darker and the fake is very bright red.
  • The elements inside the white box where the barcode and part number are at are all present, but oriented relative to each other in a way that Honda doesn't actually use, the aspect ratio of the barcode is wrong, and the font is wrong.
  • The period at the end of the Japanese text is a Western-style filled-in dot. On the real filters, it's a hollow circle as it should be for Japanese writing.
  • There's an apostrophe missing in the French instructions.
  • There's a space missing after a comma in the German instructions.
  • Real filters *from Japan* don't have a second label on the shrink wrap that I've ever seen.
  • The "9M31" is some sort of date code or lot number, and recent production has added a fifth digit at the start of those. They've been starting with a B (and if I had to guess, C, D, etc. soon since it seems to "count up") But importantly, "9M31" was copied from one of the date codes on pictures published by real vendors. If you look at my real examples above, you'll see a "9M31" and that's likely where this counterfeiter got that number from. If you get a real filter, you shouldn't expect that code to match any pictures you see online. They'll probably all be the same code in a pack of multiple filters though, since it's not a serial number or anything like that.
  • Newer production ones have a QR code on the label like in the first example. While this could be faked, the QR code should have the date code (or lot number?) embedded in it.
mattrose4
chicago
2023 civic type R, 2013 sti
This is interesting. I also got the 3 pack on amazon with the crush washers, but the washers were in a little bag and not in the box. Shrink wrap was tight too so I'm not too sure. Maybe AMs filter is the way to go 🤔
Xmetal
CTR, S3
I've stopped buying mission critical automotive parts from Amazon a long long time ago. I would rather pick something up from a local franchise parts store than Amazon. Ebay only if I know it's from a legitimate dealer.
Spart
2025 Integra Type S
Post a picture of the boxes the filters are in.
