How bad are Rota Slipstreams?
jdezee
Jack
sanford, FL
I want sw388's but don't know if I can stomach the 5k for rims alone when the rota slipstream are a full set for the price of one sw388.
I know the basic difference in quality and forged vs cast so not trying to compare the rotas to the spoon or regamasters.
I wanted to get first hand feedback from those who have owned the rotas.
Not looking to track the vehicle with them either.
Also any issues with wheelbay as a seller on ebay?
Link for attention
https://ebay.us/m/UXlF9Z
comps
kay
required
required
I havent heard of Rotas since the honda-tech days. From what I remember the company was banned and they crushed all the rims in the Philippines. I wouldnt put those on a $45,000 car.
I was slowly buying rims from blackhawk japan and have one spoon wheel. too bad its 5 x 114, id sell it to you haha.
jdezee
jdezee
Jack
sanford, FL
I had a shot at buying a set of sw388s with tires locally for 4500, but it slipped past me. Honestly I love my stock wheels with 20mm spacers. I will prob hold out until I can get the sw388s I really want. The 18x9.5 +40 is my dream wheel right now.
comps
kay
required
required
It's for sure the cleanest rim out there. How about the russian version? Regamasters from ICB? The website is 25 years old but I still think the shop is still in business haah.
jdezee
jdezee
Jack
sanford, FL
For some reason the regamasters don't come in a 18x9.5+40. That is for sure the fitment I want. On a 275/35r18 tire.
iforgettopee
jeff
los angeles
pretty neat that they're hub centric
Rota's been in business for a long time - I don't think you have much to worry about for street rollers
I don't think you're gonna find many people raving about having Rota's on their FL5 either
Evox787
Elvin
2024 civic type R , Evo X 2010, Scion XA 2006
Man I remember back in 2007 around that time they trash them becas couple of dudes went to a track hit a wall, kerb or something above 100 miles per hour and the wheels got destroyed, so everyone bashed them but I own a set of 4 spoke to use on my daily for 5 years and never have any issues with them. But the same kind of stuff was said about Konig and look now. Go for it man is you car at the end of the day if you like them go for it.
2023 CTR #3177
Rotas are inexpensive, cast wheels and usually copies of licensed designs. There is nothing wrong with them if you are just looking to buy wheels for a look and aren't concerned whether they are the most durable or lightest. Also make for cheap snow wheels, track wheels, etc.
I like them for what they are, I've run many sets on my old NA Miata and tons of Miata folks run them. They are from the Philipines as mentioned, I had them do a special run of 13x8 +4 RBs (Panasport clone) for CSP class Miatas back around 2005 or so to run 235 width R compounds for autocross. Super cheap, like $100/wheel.
coldradio1
Oliver
Nashville, TN
Have you looked at Desmond Regamasters? Basically the same wheel as sw388 with different finishes and without the Spoon tax. Forged, made in Japan, and about $1,500+ cheaper than the Spoons.
jdezee
jdezee
Jack
sanford, FL
Yea I have but I can't seem to find the exact size I want in the regamaster. I want a 18x9.5 +40mm, they seem to only have +38 or +45
NeRO_CTR
Joeeezy
Commiefornia
hope this helps.... 2mm is as thick as a nickel. Your wheels will stick out one nickel further running 18x9.5 +38, with a +45, it will sit inset, by 1 nickle and 2 pennies. Happy hunting.
11th Gen Honda Civic How bad are Rota Slipstreams? 1748217066673-kd
CR-X
Chris
Toronto
2018 Civic
Check out Superspeed wheels. Cheap, light and fairly strong.
Anthonyfa18
Anthony Mark
Laval Quebec Canada
Honda’s
It look like rota makes exact replica of the spoon sw388 has anyone installed them?
The spec
ROTA Wheel Slipstream-R (18x9.5, 5x120+40mm, 64.1mm Hub)
Part Number: ROTA-SS-R-1895-5120_40-64
-: Size: 18x9.5 Pattern 5x120
-: Offset: +40mm, Hub Bore: 64.1mm
-: Wheel Average Weight: 21.2 lbs
https://www.wheeltech360.com/ROTA-W...8n0bxfI09LgaE864Xsqx6ScLYzBbGgFufpgLiigoeDvY4
https://ebay.us/m/mppLmP
vs
Spoon SW388 18"9.5J +40 5H120
Machine Forged. Anodized Black Finish. Made in Japan.
7.7kg (16.97 lbs) per wheel.
Hub Bore: Φ64.1
Part Number:42703-1895-40
https://spoonusa.com/spoon-sw388-18-9-5j-40-5h120-accessories-black
https://www.blackhawkjapan.com/products/spoon-42703-1895-40?_pos=6&_sid=48e0d2a4c&_ss=r
The only thing I see different is the weight of the mags
jdezee
jdezee
Jack
sanford, FL
The spec
vs
Hub Bore: Φ64.1
This is exactly my biggest issue right now. If Im not going to track the car, is it worth the extra 4k to get Spoon wheels when they are the exact same spec, I think I may end up buying some Rota's to cruise around town in and if they suck I will at least have tires for different wheels.
