All the Available Aftermarket FMICs are Bad
svvitch
Thanks and I am curious...Were those logs recorded while also using the OEM downpipe and OEM turbo/downpipe shielding?
Yea I haven't touched turbo or downpipe. I am tuned however with a jester track tune so a bit more conservative.
ctechauto
We're waiting for our shipment of HKS intercooler kits to arrive. Really excited for them and do some real world testing and logging. Tube & fin ultimately nets lighter material weight and theoretically more efficient over B&P (not 1:1 - many factors involved), but ones like the PRL do have billet end tanks which is also a popular IC we sell, albeit quite heavy unit.
blueroadster
MD
For a mod to help keep things much cooler under the hood, I would suggest considering thermal shielding to add to the downpipe in particular. That would help insulate the large surface area and high temps from radiating to other components.
Here is the build thread for my car where I am installing parts individually over time. Overall, my plan is to stick with the OEM turbo and fuel system. I recently added thermal shielding to the turbo and downpipe areas where they resulted in the most noticeable improvement in reducing under hood temps to help keep coolant and IATs in check.
Piibuhh
Bing
Socal
Do you know if we can run the hks intercooler with stock pipping or we do we need the hks specific piping kit?
ctechauto
Yes, there is both options available: intercooler itself to reuse OEM piping or the full kit with aluminum IC piping and silicone hose kits.
Also can purchase the piping kit separately if you want to upgrade later.
Here is the link for the full kit: https://ctechautomotive.com/product...ercooler-kit-fl5?_pos=26&_sid=895a48f5c&_ss=r
Core only: https://ctechautomotive.com/product...75898&pr_ref_pid=9877412643130&pr_seq=uniform
blueroadster
MD
HKS IC by itself bolts up to the stock IC piping without issue. Better to order the complete HKS IC kit as it includes replacement piping. Adding the piping kit later would add much more to the overall out of pocket cost.
Here is a link where I added the HKS IC piping to a J's Racing intercooler. Previously, I was using the OEM IC connections. HKS piping kit will work with any aftermarket IC that uses the OEM connection points.
Piibuhh
Bing
Socal
Thank you for the insight.
SKINNIE
DFW TX
ISF, 23' BB FL5
What's the ETA on the HKS intercooler kits?
west357
Matthew
ohio
honda civic type R
FYI call pwr directly to order. That’s what did and I got these intercooler for $1661 out the door shipped.
11th Gen Honda Civic All the Available Aftermarket FMICs are Bad IMG_3924
