Nothing
2023 CW FL5 #5044
Does the fitment come down to 18", 275 tire and +40 being ideal? If 275 works well with 9.5", then as long as it is +40 it would fit the same.
Typically we see +38, which is a camber adjustment, but probably more variability in tire models and ride height.
nttran98
Nhan
2026 FL5
I just found and I hope someone do this is BMW Style 513M would be 5x120 18x10 +40 spec for the rears. I hope someone do it.
rondre3000
San Diego, CA
H&R Fk8 springs - 265/35/18 // 18x10 +40 // -3front / -2rear
How long after install was this pic taken? Curious because I'd like to know how long it takes these springs to settle. Your ride height looks a tad lower than mine and my springs are about 2 weeks old but only 150'ish miles since install.
-Ron.
iforgettopee
jeff
los angeles
i think it was after ~500 miles - i'd say mine are settled in the picture
driving in comfort would help settle springs faster
it would be interesting to have our cars side by side to compare the FK8 spring drop vs FL5 spring drop. FL5 specific H&R springs should be 5mm higher in the rear.
If you're going to the Hondata jailbreak thing in SD July 5th we can do a side by side.
rondre3000
San Diego, CA
Thx...I was on the fence about going but now May have more of a reason, even if only to hang out.
Sinner
Delaware
2024 FL5
God spec GT Beyond
RSR coilovers
275/35 V601’s
There’s a little poke on the front but it’s still settling. I’ll probably lower the front another quarter inch
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1051
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1049
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1050
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1052
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1067
ctechauto
Got one of our orders in for new wheels.
Volk Racing CE28N Plus M-Spec in Diamond Silver
18x10 +40 5x120
Yokohama Advan Neova AD09 285/30/18 (originally wanted to do 295/30 but 295 was on backorder from our distributor).
We have a set incoming for fall for same spec CE28N Plus M-Spec but in Diamond Dark Gunmetal and will be for sale!
