SBX Performance
SBX Performance
Poughkeepsie
www.sbxperformance.com
2024 Honda Civic Type R
I say you don't do cerakote and try to get a swaintech coating going, it's a million times better and actually helps with temps unlike cerakotes 🫣
Im giving that option that company is actually in NY so makes it easy for me :) and agreed this downpipe isnt meant to be pretty I want it to perform no cheap coating options to make it all fancy. I rather have something that works.
SBX Performance
SBX Performance
Poughkeepsie
Sweet and thanks for the detailed reply...Count me in for an interest in ordering the downpipe. As for joining another mailing list, I'll pass.
When do you anticipate that the downpipe will be ready for production and shipment?
Also, what is the ID on the 3" downpipe outlet that connects to the front pipe? Stock downpipe ID on that connection point is 53mm (2.09") and TSP downpipe ID is 72mm (2.83").
I currently have the TSP downpipe installed and mated to a Fujitsubo front pipe measuring 70mm (2.76") and then connecting to a Fujitsubo titanium exhaust of the same diameter.
As of now...Myself and the fab shop looked at the outlet to front pipe to see what we can do and whats best. Looks like 2.87 and some change will be the opening. Its a normal 3 inch pipe at the bottom and that is what the ID comes to. This will allow it to match up any bigger and I will have to adjust and do a custom flange which will add money so def not. The 3.5 off the turbo is the most important part of the downpipe so at least I can opening her up there. Should have the V2 protoype here next week
Thanks for the update and awesome...Looking forward to the release. Any thoughts on offering a combo deal on the catted and non-catted?
I actually found out too recently lol, middle of nowhere near Rochester
SBX Performance
SBX Performance
Poughkeepsie
Not a bad idea at all! The issue is I’m not opening the catless stuff up to just anyone. I’m definitely going to stay strict with that. Even though the EPA seems to be easing up a bit with the new admin, I still need to protect my business.
Understandable...Thanks!
SBX Performance
SBX Performance
Poughkeepsie
After a lot of fitment testing, flow testing, and going back and forth on designs, I decided to go back to my original plan for the SBX downpipe setup: Yes I know I change my mind a lot but its always for a better reason.
4" off the turbo → 4.5" GESI cat → 3.5" to 3" lower section.
The area right off the turbo is the most important part for reducing backpressure and helping exhaust gases get out as efficiently as possible. Keeping a true 4" transition off the turbo lets the exhaust expand smoother before hitting the catalyst.
The larger 4.5" GESI cat also helps with:
• better overall flow
• less restriction at higher power (Up to 850hp)
• smoother airflow through the core
• better heat management under load
Then tapering down lower in the pipe helps with fitment, chassis clearance, OEM-style compatibility, and keeping exhaust velocity balanced without creating unnecessary restriction.
A lot of companies build around what’s easiest to manufacture and cheapest to make overseas or package. I’m trying to build around what actually works best while still fitting properly and feeling OEM+.
SBX Performance — not just making noise, making power efficiently.
Updates.....
Will have some data on Tuesday it looks like here is some updated pics. The prototype is not that pretty now cause we had to cut off the 3.5 inch elbow to put the 4 inch elbow on :) also I did not put the heat shield option on the protoype. I have an extra bung for the backpressure sensor to go on. anywhere here it is. Pre order open next week just waiting on the price quote for the 4 inch elbow. Oh and the SBX logo will be the opposite way. it matched up well with my Spoon exhaust front pipe which is 66 and change mm
Desk chair quarterback here...Looking awesome...Glad to hear that you went back to using the 4" elbow off of the turbine.
SBX Performance
SBX Performance
Poughkeepsie
This downpipe looks promising. Cant wait to see it finished up
Thanks, I am really trying to make something great that actually works! They are all hand made so going to be limited runs each time.
Right now a customer of mine has it on his STOCK DE5 testing it and he is going to the dyno on Tuesday night to compare stock vs with the downpipe and also backpressure on the SBX and also checking no CEL. I figured what better than me testing it? Customers who will be honest with feedback. He is sending it back to me after that so no bias free shit.
22Si
IL
2025 FL5
Great way to test it. How does it sound on factory exhaust? I know DE5 has one else resonator
SBX Performance
SBX Performance
Poughkeepsie
He is going to make videos today of exhaust! funny i just told him to do that last night. Hard to find a stock car to test things on so its a perfect opportunity
SBX Performance
SBX Performance
Poughkeepsie
DE5 test car install went well besides one stud he left before it snapped LOL first video is OEM second video is SBX Downpipe he is going to do some revs later he is on his way out in his vet for a car show. Will post it later of the revs. Also the extra bung is for my backpressure sensor ignore it
SBX Performance
SBX Performance
Poughkeepsie
Completely Stock DE5 Testing
No codes found and more sound. Customer said more pops and bangs heard and feels quicker but could be the louder tone LOL
Videos of stock downpipe and stock exhaust vs SBX downpipe with stock exhaust.
Video 1 and 2 sbx video 3 stock
