1. Has anyone added a quarter wave or helmholtz resonator? 2. Individual mode + mode adjustments with dual resonator delete.
Mawfuqqa
FL5 #9000!!
Did dual resonator delete, while does not drone too loud (can still talk at normal voice levels in car) it has an annoying frequency
I've got a helmholtz resonator calculated for drone around 2200-3200 rpm at around 42" in length which should easily sit next to the dual delete area.
22Si
IL
2025 FL5
Let us know how it works out
Mawfuqqa
Mawfuqqa
FL5 #9000!!
I did not do a drone pipe yet but I would like to update and get some insight on driving mode adjustment.
I have not touched anything outside of individual mode in months until drive home from work today I set it in comfort. I had a welcoming surprise of the interior drone/sound being cut by a significant margin.
Odd considering in individual mode I have SOUND in COMFORT. Is individual mode actually non functional to some degree?
Xmetal
CTR, S3
I believed the SOUND setting controls the fake engine sound and not the exhaust flap. The exhaust flap is most likely tied to one of the 3 standard modes. But come beg the question - what is the default exhaust flap setting in individual mode?
The sound setting controls the fake noise. The engine setting controls the exhaust valve, as well as the throttle settings. So comfort engine setting=quiet exhaust.
Mawfuqqa
Mawfuqqa
FL5 #9000!!
Interesting, will try the engine in comfort unfortunately will lose the throttle response.
Mawfuqqa
Mawfuqqa
FL5 #9000!!
Engine set to comfort works.
@22Si
No fuse mod and fake sound module still plugged in.
Drone is a 1 in comfort. In r+ about a 4
Engine in comfort needs a lot more throttle and higher rpm to start boosting. Over 50% to even boost single digit psi. In R+ by around 25% throttle and less rpm it’s boosting single digit psi. Max ~18 psi at WOT in comfort. Whereas R+ engine will take it to 20+ psi
Wonder if it’s actually saving more gas as it’s intended to. I’m throttling at 40-60% and for longer duration/higher rpm to reach desired speed commuting the same roads. It’s not bad, just different. Throttle response isn’t particularly bad. It’s just more time running in N/A seemingly
