19x10 +45mm wheels
marcusm86
Marcus
Missouri
2025 Civic Type-R
This is definitely my area of least expertise. It looks like a few people are running 19x10 wheels, and 275/30 tires. I guess I just wanted to know if there were any other options for tire sizes on the stock suspension or what the suggested "range" would be (for 19x10 +45 wheels). I do know that tires are like shoes and the same numbers doesn't mean its the same size. TIA
Sporky McGeuschky
Sporky
Central Texas
Hi.
With stock suspension and 19X10 wheels, you can probaby go up to a 285/35 ZR19 size tire without issue, depending on the tire.
I wanna see photos when you do it!
Cheers.
marcusm86
marcusm86
Marcus
Missouri
2025 Civic Type-R
All I have is an AI photo right now.. still will have to wait until i acquire all 4 and decide if I'm gonna powder coat them or not. May be some time as I'm trying to kind of do this on a budget.. extra wheels aren't a pressing issue for me right now either. I do appreciate your answer and am willing to share AI generated photos if you are interested.
Sporky McGeuschky
Sporky
Central Texas
Yeah, that would be sweet. I'm not a super fan of AI, but I do know it has its legitimate use cases.
marcusm86
marcusm86
Marcus
Missouri
2025 Civic Type-R
found some of these BMW 5 spoke style 132 rims goin for kinda cheap (remanded) online and if im buying rims for my car, i dont want what everyone else has personally. just did colors to see.. i think i like the red the most?.. anyway heres some slop starting after the actual wheel and on an actual car.
11th Gen Honda Civic 19x10 +45mm wheels 1772989501100-c
11th Gen Honda Civic 19x10 +45mm wheels 1772989482333-gf
11th Gen Honda Civic 19x10 +45mm wheels 1772989530100-2y
11th Gen Honda Civic 19x10 +45mm wheels 1772989540886-y3
11th Gen Honda Civic 19x10 +45mm wheels 1772989565500-8h
11th Gen Honda Civic 19x10 +45mm wheels 1772989573267-18
11th Gen Honda Civic 19x10 +45mm wheels 1772989580358-if
Sporky McGeuschky
Sporky
Central Texas
Nooice.
Yep, color swapping is definitely a good use for AI. The used Beamer wheels look good, too.
I take it your FL5 is Boost Blue?
APEXRaceParts
BMW
From a suspension and fender clearance perspective you'll be fine. I'd say to keep an eye out for brake clearance.
Tire sizing wise, I'd suggest a 275/30-19 if you're looking for something direct-fit. While you might able to get away with the width of a 285mm tire, you'd likely get stuck with a 285/35 and that sidewall will be huge. It could end up causing more headache than it's worth.
Edit: I just realized I missed this part. The reason I said "stuck with a 285/35" is because there aren't very many 285/30-19 tires around. So with limited tire choices, you might end up with a size you don't want, just to get the tire model you do want.
Jack90210
Central VA, USA
2025 Type R
I, uh ... I'll be in my bunk 💦
marcusm86
marcusm86
Marcus
Missouri
2025 Civic Type-R
its gonna be a bit longer for me to do this.. i bought an intercooler instead lol. I do hope to have something figured out by winter tho
^Actual expert.
I have to admit, those wheels look interesting on this car. I would have assumed the offset would be the dealbreaker on a BMW but what do I know. +45 on a 10" wheel theoretically would work on this platform, assuming the brakes clear- which is crucial because the front brakes aren't necessarily small on this platform.
Just doing a touch of research, looks like these wheels were a staggered fitment (from an E53 X5, according to Gemini) so finding a set that are all 10" would be interesting.
Regardless, good luck? But I would def do a test fit before buying anything.
Xmetal
CTR, S3
I have an e53 X5 and have these wheels. They are staggered, so finding a genuine set with 4 matching wheels would be difficult, but I have seen replicas that are in non-stagger setup. With that said, I would not use them on the FL5. Those type 32 are heavy! The 19x10 is about 35-40 lbs each! Talk about putting boat anchor on the FL5!
lflouie
jeff
Knoxville, TN
Audi S4, Audi A4
Is the reason you are looking at larger tires (wheels) for increased grip or for looks/style?
Adding both larger heavier wheels and tires will make the car drive and feel much less responsive and susceptible to tramlining.
marcusm86
marcusm86
Marcus
Missouri
2025 Civic Type-R
100% looks
