Jester Tuned high pressure fuel line
Hey guys so this is something I have been working now for the last 4 months. I said in a couple of posts that I was working on something and this is it.
The Jester Tuned High pressure fuel line. Engineered to perform in the harshest conditions. Working pressures in excess of 5000psi with a burst pressure of 16,000psi. Flexible hose with ptfe lining that has extremely low pemeation. This is the line to completely eliminate any issues regarding cracked lines. Aerospace engineered, you would find a line like this on a rocket.
This line is made with flexible stainless steel braided and ptfe lined. Forged machined fittings and connectors. No brazing here to crack or possibly fail.
This is a project of love to give back to the community that has cost a lot of time and effort to achieve but I genuinely believe you guys deserve the best. This line has no bends or kinks, just a straight through design with a internal diameter for fuel flow for over 1000hp.
Quantities will be limited at 50 units with a price of $499. Yes it is more expensive than other options but the quality and design of the line speaks for itself. Possibility of making more but they will need to be preordered. So if you were waiting for an upgrade this is it.
preorders will be available through vtecslayer exclusively.
Pictures of the actual product. Patent Pending
https://vtecslayer.com/products/hpf...tent=JesterTunedLine&utm_medium=product-links
11th Gen Honda Civic Jester Tuned high pressure fuel line IMG_9938
11th Gen Honda Civic Jester Tuned high pressure fuel line IMG_9939
blueroadster
MD
Does the SS exterior braid come into contact with any other part after installation or during use when the motor is torquing under load?
jmheath357
Phoenix, AZ
2025 Honda Civic Type R
If it does, you could always wrap it in chafe tape to prevent any wear. I'd probably wrap it before installing it just to make it easier, that is of course if it looked like it would come into contact any other lines, hoses, harnesses, etc.
HondaHoon
Western Maryland, USA
RaceFlux fire-retardant silicone fiberglass sleeving, or something similar. This would serve multiple purposes, including any possibility of damaging wiring. However, it is probably completely unnecessary. However, I have this stuff on my WOT dual oil cooler setup, and it is amazing quality.
No sir! Will fit like stock
