90's Kid Dream Build
Which mode do you normally drive in? I have no intention on doing suspension changes because I do not want to make the ride harder than it is now for my wife and son. But if this is a better ride, I might give it a try.
TunerR1
TunerR1
Ge
Wisconsin, USA
2015 Toyota Tacoma, 2023 Civic Type R
I drive in individual mode; everything in basically R setting but my suspension damper set to comfort, lol.
Installed the Wunderladen Racing Rear caliper bushings today. Here’s the OEM rubber vs brass bushings.
I bought this but haven’t installed it. Do you feel any difference?
TunerR1
TunerR1
Ge
Wisconsin, USA
Put the acuity shifter bushings in; I drop a washer down the openings into the carpet. What should’ve been a 30min job turned into 1 1/2 hour as I put tape on the end of an extension to attempt to stick onto the washer and pull it out. After many attempts I got it out lol. Install is done. Definitely firmer shifts; more slamming gears in the future.
11th Gen Honda Civic 90's Kid Dream Build IMG_2328
WeudS
Daoud
MA
2023 RR CTR, 2023 MDX Type S
Glad to hear you got it done. The same thing happened when I tried it on my FK8. My wife was not pleased to say the least.
TunerR1
TunerR1
Ge
Wisconsin, USA
I did the clutch delay valve delete; now it’s shifting like how I want it to; full complete control of the clutch. I can’t stand these driving aids so out it went. No more gear lock outs/grinds due to slow disengagements when shifting quickly; people say it doesn’t affect disengagement but only slows reengagement of the clutch. I beg to differ. It restricts flow both ways. Anyhow I’m in love with how precise and controlled it feels now.
11th Gen Honda Civic 90's Kid Dream Build IMG_2356
I also went and got the front mugen lip; I don’t like the side skirts too much so still undecided. Mugen does require you to drill 2 small holes; after much double sided tape attempts; nothing will stick to the ceramic coating so I drilled using the template and it turned out awesome.
11th Gen Honda Civic 90's Kid Dream Build IMG_2409
Wheels are the next mod; but I’ve been undecided; too many TE37s out there so that’s out of my selection at least for now.
TunerR1
TunerR1
Ge
Wisconsin, USA
After reading the Off the shelf tune thread on here I came to the conclusion to go with the TSP Stage 1 tune; it really woke the car up. It’ll keep my need for more power down a little longer while I plan fuel and turbo upgrades in the future. I intend to grow old with this car so lots to do. Lol
TunerR1
TunerR1
Ge
Wisconsin, USA
11th Gen Honda Civic 90's Kid Dream Build IMG_2441
installed the brake shims today; got a rock stuck in the dust shield so decided to throw these on. These pads are quite dusty I suppose I’d replace them once I get aftermarket wheels.
TunerR1
TunerR1
Ge
Wisconsin, USA
Went with some Paragon rear rotors and P2 pads;
I debated on a set of the larger 350mm rotors but after much consideration; I vouch to reduce as much rotational mass as possible thus went with these.
I also ordered the front ones too but didn’t get to installing them yet.
11th Gen Honda Civic 90's Kid Dream Build IMG_2610
11th Gen Honda Civic 90's Kid Dream Build IMG_2608
TunerR1
TunerR1
Ge
Wisconsin, USA
Got one side in front done; will do the other tomorrow. Had to run out and get a torque wrench capable of 10.5ft lbs or 125in lbs. Just a note for future folks who wants to do the rotor swap.
I weigh the rotors from OEM vs Bolt on Paragon and I’m seeing a 1 lbs difference with the Paragon being lighter, which is not bad; but I do have a 1990s bathroom scale lol. I would say with a margin of error they weight the same!
11th Gen Honda Civic 90's Kid Dream Build IMG_2613
11th Gen Honda Civic 90's Kid Dream Build IMG_2612
TunerR1
TunerR1
Ge
Wisconsin, USA
Some updated photos; it’s a hard choice to go with some aftermarket wheels when the OEM ones look so good.
Really been considering the Mugen side skirts and rear splats but hate how fat the Mugen skirts look. So holding off.
I keep saying I’d do turbo and fuel, but I can’t seem to get there yet; donations are welcome hahaha, Slow but steady the car is coming together quite nicely.
I have some more dress up ideas that I’d be tackling in the coming weeks.
11th Gen Honda Civic 90's Kid Dream Build IMG_2653
11th Gen Honda Civic 90's Kid Dream Build IMG_2651
11th Gen Honda Civic 90's Kid Dream Build IMG_2649
11th Gen Honda Civic 90's Kid Dream Build IMG_2644
11th Gen Honda Civic 90's Kid Dream Build IMG_2648
Websitesdown
I've had mine three months and had the tint done all the way around so far. That was $1050. I understand the money part. I'm getting the ecu chipped and tuner / tune this check. I can't wait for the exhaust myself. Looks good man!
