Adaptive Damper system error !!!SEE YOUR DEALER
vaskaskh
Vaska
Georgia
Honda Civic type R FL5
Hi everyone,
I'm in the final stages of rebuilding my Civic Type R FL5, and everything is nearly complete. However, I've encountered an issue: I'm getting an "Adaptive Damper System Error – See Your Dealer" message.
I've checked all four wiring harnesses, and they are fully intact. I was able to successfully clear the check engine light and collision history using a basic mobile OBD scanner.
My question is:
Does this Adaptive Damper System Error require a more advanced diagnostic tool (like a professional tablet-style OBD), or is there a way to reset or clear this error through hidden steps or procedures?
Any advice or shared experience would be greatly appreciated.
Thanks in advance!
11th Gen Honda Civic Adaptive Damper system error !!!SEE YOUR DEALER 24c73eb5-011d-424e-a810-36db83304edf (1)
HECTOFL5TYPER
Hector
2025 TYPE R
Ok, I’m taking a shot at it. I wonder if the code is stored in the suspension module. You might need a Bi Scanner, to read all the modules on the car. Autel sells some decent ones. But my bet is your suspension module. Might need to send it in to reset. Or you can always buy the Type S module for the ride comfort. Again this is my guess. Keep us updated.
vaskaskh
vaskaskh
Vaska
Georgia
Fixed!!! “adaptive damper system see your dealer problem” it was headlight right sensor. I had spare sensor from back suspension, transferred to the front iron body plugged in and instantly error is gone
11th Gen Honda Civic Adaptive Damper system error !!!SEE YOUR DEALER IMG_9238
11th Gen Honda Civic Adaptive Damper system error !!!SEE YOUR DEALER IMG_9237
vaskaskh
vaskaskh
Vaska
Georgia
I scanned with launch obd scanner , error was lost communication to the right sensor (i thought it was only for headlight), every wiring seemed fine so i just plugged headlight sensor wiring (even damaged sensor fixed it) and it worked.
vaskaskh
vaskaskh
Vaska
Georgia
Scanner did not help same message was visible on mobile phone cheap obd
Superhatch
Jacob
Wisconsin
I had to check if this was an old post from April 1.
This all makes sense, very cool. Can't wait to troubleshoot this car when it gets older.
vaskaskh
vaskaskh
Vaska
Georgia
I guess hanger just makes sure it is fixed positioned (i guess when cornering it should be levelled at the same height, as it has 4 of them on each wheel ) . there is no other use than that i can think of. its just a wire whicu should be plugged.
MyFL5
abigail
Prescott
2024 Fl5
I cant find this sensor anywhere? Do you know what i need to look up
scottjua
Scott
Plano, TX
I think he meant “ride height” sensor???
