Audio Update, Bad News
AshSerigala
11-Gen Honda Civic Hatchback Sport-Touring
I did always wonder how tricky it would be to do an audio swap on an 11 gen civic sport-touring.
The center speaker when connected to android auto at least, plays your notification sounds, google-maps voice nav sounds, etc.
But yeah. It kinda sucks because with my past car, Chevy Spark, I just put a fiber optic headunit into the car and ran everything through a JL-TuN, piping out to sundown amps and sundown subs...focals for everything else. I ditched all that when the Spark died and used the sales to fund the civic. I did want to look into the door speakers and such. To see if they are standard ohm or some special BS so you cant swap them out easily..? I almost half assume "Oh simple just cut all the front/rear/sub speaker wires, pipe them into a JL-TWK, and bam." As thats what I've done with past cars where I kept a stock headunit. Speaker-Level in, Line-Level + Fiber out. Automatically syncs the EQ flat via a test tone that plays a ton of tones at ones. And then you can fine-dial on the TuN.
But from what I gather above that may not be a "doable" option.. Guess will see whenever I decide to adventure this! Just had to know what I want to do. Kinda had my "Fun" When I was rocking enough to blur your vision. Now days I'm almost honestly okay with stock, Just wanting more low-end ( ported ). Having ran dual 8" X.V3's Sundowns in the past..been lightly debating trying Deaf Bonce just for something different. Single 12.
But if I read correct, theres SPDIF Fiber feeding into the bose amp? Do you know if its full-range un-modified? As if thats the case, I'm sure my JL-TuN can process it and then I just plug amps in and boom..done. Tune EQ by ear or tune by mic.
ThirtyHz
ThirtyHz
Michael
Elgin, IL
2022 Civic Si, 2016 Ford Focus
This is fantastic, thanks! That's an insane amp! What subs do you have for 3.5KW? I'm curious about your speakers. I went with a 10" JL sub and some Blam! 165P speakers in my 10th gen and they do alright without a DSP/Amp but I'm looking for a serious upgrade when I go to the 11th gen.
Does that Sundown get hot inside the foam? Any issues with heat back there?
QQ about the center speaker; is it balanced or is it just for the system sounds, voice control, etc? Did you bother replacing it?
*edit*
If I were looking for something other than the DM-608 -- is it using the optical spdif or the coax cable?
So when it comes to the center speaker, I completely disconnected it. Unfortunately that center speaker plays both music and all voice for phone calls, navigation etc. I’m currently living without but will eventually figure out a solution to retain it.
The amp does become quite hot at higher volumes and load, but no issues yet. For day to day use, I’ve been running a Sound Solutions Audio ICON 12” sub. My DSP preamp voltage going to the sub amp is at a conservative level so I’m in a safe spot with that sub on such a large amp. Competitively, I’ve been experimenting with a variety of different Sundown Audio subs but that’s a whole different conversation.
Right now I am not using any coaxial or SPDIF from the factory wiring. Just wired in rear door speaker and factory sub high levels, which are digitally summed together and give me a fairly good source.
ThirtyHz
ThirtyHz
Michael
Elgin, IL
@ThirtyHz one more question (in addition) where is the stock amp? Is the SPDIF cable optical?
The stock amp is up in the corner of the passenger kick well near the front passenger fender, way up behind the glove box. I don’t believe it is optical, I may be mistaken, but if I remember correct it is a digital coax feed
psyborg
AB, Canada
2018 Civic Type R
Did you confirm that the coax works? I really don't want to go the channel summing route unless it's the only way. I guess I'd have to balance the output for the center speaker as well though. What a mess.
ThirtyHz
ThirtyHz
Michael
Elgin, IL
I did not confirm that, although my collection of tools is sufficient, I do not have a way of testing the coax. Only thing I did was unplug it and confirmed that audio no longer worked and plugged it back in.
xanderalex
Alex
Pasadena, CA
Honda Civic Si 2023
Trying to wire up an AIO Kicker Hideaway sub, you think I can tap into the factory trunk subwoofer?
shaner89
Shane
Ontario, Canada
2022 Honda Civic Si
Hi Everyone,
I am posting the information below to help those wanting to install a good aftermarket stereo and still retain the factory radio without having to deal with Bose EQed signal after the amplifier. This applies to the 9" display/Bose amplified set-up not the basic 7" display/8speaker. In the diagram below of the factory 9" head unit in the left picture (mounted below the screen in the center of the dash, on the 7' factory radio's it is part of the screen as shown in comparison below) you can see all the plugs in the back. The bottom right plug is the plug that outputs the speaker signals on the base system. On the connector view you can see below that some pins have *1 (w/8 speakers) on pins A5-A8 and pins A15-A18 because if you have the 12 speaker system these pins are not used due to the fact these outputs come out of the Bose amp instead. My suspicion is that these pins are likely still fed an audio signal and our systems just have no pins and wires in the connector, they are blank. I am going to pull the plug off the head unit in the dash and install pins in the blank locations and hook up speakers and see if I get output. If there is output, it would be a fantastic source to use for a DSP or LOC for an aftermarket amp setup. I may not get to this for a couple weeks but I will report back if it works. If anyone has the chance to test this before me, please report back. The only issue with this setup is that I am not yet sure if we will lose any functionality from deleting the Bose amp. I am excited to try this because I would love to delete the Bose amp and build a really nice stereo like I've done in my other vehicles. You could unplug the Bose amplifier out connector and feed your speakers from your amp to there and replace all door speakers and tweeters with better equipment. There are also some hidden menus on this system, not sure if we would have to go in under audio and change any settings to get output from these pins? I am going to play around with this and report back.
Below the head unit connector view, I have included the Bose amplifier connector view for those wanting to tap in after the amplifier. ( I will be doing it this way if the first option doesn't work) Hopefully this helps some people!
11th Gen Honda Civic Audio Update, Bad News 1686062303770
11th Gen Honda Civic Audio Update, Bad News 1686063099735
CavityTerminal NameDescription
A1GNDGround for audio unit (G013)
A2GNDGround for audio unit (G013)
A3+B AUDIOContinuous power source
A4+B AUDIO_SUBContinuous power source
A5*1RL_SPKR+Outputs sound signal for left rear door speaker and left rear door tweeter
A6*1RL_SPKR-Outputs sound signal for left rear door speaker and left rear door tweeter
A7*1RR_SPKR+Outputs sound signal for right rear door speaker and right rear door tweeter
A8*1RR_SPKR-Outputs sound signal for right rear door speaker and right rear door tweeter
A9Not used―――
A10Not used―――
A11Not used―――
A12K-LINEDetects scan tool signal (serial data)
A13Not used―――
A14YB-CAN A_HCommunication signal
A15*1FL_SPKR+Outputs sound signal for driver's door speaker and left front tweeter
A16*1FL_SPKR-Outputs sound signal for driver's door speaker and left front tweeter
A17*1FR_SPKR+Outputs sound signal for front passenger's door speaker and right front tweeter
*1: With 8 speakers
*2: With 12 speakers
*3: USA/Canada models
*4: Mexico models
*5: Type-R/Si
A18*1FR_SPKR-Outputs sound signal for front passenger's door speaker and right front tweeter
A19Not used―――
A20BACK_LTDetects reverse signal
A21*2SWD+BOutputs signal for stereo amplifier and active sound control unit*5 switching on/off
A22VSPInputs vehicle speed pulse
A23IG1_WITH_DIODE_FMVSS*3Power source for accessories or detects reverse signal
ACC*4Power source for accessories
A24YB-CAN A_LCommunication signal
*1: With 8 speakers
*4: Mexico models
*5: Type-R/Si
11th Gen Honda Civic Audio Update, Bad News 1686063406460
A1GNDGround for stereo amplifier (G005)
A2SUB_WOOFER+Outputs sound signal for subwoofer
A3+B_AUDIO_AMPContinuous power source
A4SUB_WOOFER-Outputs sound signal for subwoofer
A5CTR SPKR+Outputs sound signal for front center speaker
A6CTR SPKR-Outputs sound signal for front center speaker
A7FL_SPKR-Outputs sound signal for driver's door speaker
A8FL_SPKR+Outputs sound signal for driver's door speaker
A9FR_SPKR+Outputs sound signal for front passenger's door speaker
A10FR_SPKR-Outputs sound signal for front passenger's door speaker
A11RR_DOOR_SPKR+Outputs sound signal for right rear door speaker and right rear door tweeter
A12RR_DOOR_SPKR-Outputs sound signal for right rear door speaker and right rear door tweeter
A13RL_DOOR_SPKR-Outputs sound signal for left rear door speaker and left rear door tweeter
A14RL_DOOR_SPKR+Outputs sound signal for left rear door speaker and left rear door tweeter
A15Not used―――
A16Not used―――
A17Not used―――
A18SATL_SP+(N/W_IN)Outputs sound signal for left satellite speaker
A19SATL_SP-(N/W_IN)Outputs sound signal for left satellite speaker
A20SATR_SP-(N/W_IN)Outputs sound signal for right satellite speaker
A21SATR_SP+(N/W_IN)Outputs sound signal for right satellite speaker
A22FR_TWEETER+Outputs sound signal for right front tweeter
A23FR_TWEETER-Outputs sound signal for right front tweeter
A24FL_TWEETER+Outputs sound signal for left front tweeter
A25FL_TWEETER-Outputs sound signal for left front tweeter
A26Not used―――
B1*ANC_R-Inputs signal for acceleration sound enhancement from active sound control unit
B2*ANC_F-Inputs signal for acceleration sound enhancement from active sound control unit
B3Not used―――
B4AUX BEEPInputs system beep signal
B5AUX NAVI GNDBasis ground for terminals No. 4 and No. 12
B6Not used―――
B7RS485-Communication signal for audio unit
B8Not used―――
B9*ANC_R+Inputs signal for acceleration sound enhancement from active sound control unit
B10*ANC_F+Inputs signal for acceleration sound enhancement from active sound control unit
B11Not used―――
B12AUX NAVIInputs sound signal for voice guidance and Voice Recognition (VR) prompts
B13Not used―――
B14SWD+BInputs signal for stereo amplifier switching on/off
B15RS485+Communication signal for audio unit
B16Not used―――
*: Type-R/Si
Stereo Amplifier Connector C (2P) (female terminals)
Open In New TabZoom/Print​
C1SPDIF2 SIGCommunication signal for audio unit
C2SH(SPDIF2 SIG)Shield for terminal No. 1
17SIYoDood
Timothy
Philly
17 Si
so the left picture is the Si infotainment and the right picture is the base infotainment? Your ( ) explanation confused me
This still may not be the perfect solution, but I wonder if you could swap-in the audio control unit Acura uses in the Integra. Perhaps it has more flexibility too??
Snmtazz70
Type R
I just installed a Audison DSP/Amplifier using all the outputs from the bose amp to the Audison dsp, it unfilters the signals to a flat. I've been tuning it and sounds damn good. Audison speakers and rockford subwoofer (might change). Lots of wiring and soldering.
matttheazn
MO
I am interested in how you achieved this. I am new to car audio. So you just tap the outputs on the head unit into the dsp? Then dsp to amp with a "clean" re-eqed signal?
Snmtazz70
Type R
If you want to keep all functions on the oem radio, tap to the output of the Bose amp, which is in the right passenger kick panel. The outputs to a dsp to clean up the signal. I have a dsp/amp with a subwoofer output, which is easier but you could go with just a dsp into an external amp(s).
Make sure you tag each output to the dsp, that way you dont overpower the tweeters.
